GT wheel downsize?
MikeInCO
Falcon, CO
22 GB GT, VW Atlas
I'm looking into going smaller on wheel diameter on my non-PE GT. Several reasons-decrease unsprung weight, more wheel options in 5x108, more tire model availability, etc. How small in diameter can I go? I'm pretty sure a 19 should be easy, but can I go down to an 18? Not sure that will fit over the brakes. Everyone wants to go bigger, and I'm wanting to be the odd man out. Thanks!
Polar
SBJ
PNW
2021 Select RWD SR
I believe all brakes are the same with the exception of the GTPE* - so you should be able to fit OEM 18” w/o issue. Or other clearance verified 18” rims.
DanoiZ
SLC, UT
2022 Ford Mustang Mach-E GT
I downsized to 18" on my GT for winter set up. I wanted less unsprung weight, more sidewall and a skinnier tire for snow. I mounted Alutec Monstr's (18x7.5) that weigh around 22lbs a piece. I've been very happy with them. Tirerack and Discount Tire will show you downsized wheels that fit the GT.
Ford Mustang Mach-E GT wheel downsize? 20221126_203237316_iOS
