Had windshield replaced. What do you recommend I test to validate all systems are functioning?
IndyJeffrey
Jeff
Indianapolis
MachE
Sadly, I needed to replace my windshield today. Everything looks fine, but I would like to ensure all of the electronics/systems/etc. are operational as with the original windshield.
I am looking for a list of things I need to check.
Thoughts?
Thanks in advance for all of the helpful suggestions.
Assuming you used a qualified company, like Safelite, then take the car for a spin with the computer and run a program to setup the camera.
BlueCruise handsfree is your ultimate test.
Sikkun
2023 Mach E
Did they charge you $1000+ for calibration….
If not, and BlueCruise works, congrats.
Creaky
Netherlands
2025 MME RWD SR
Anything with a plug on it...
After I had my windscreen replaced I had major issues with the rain sensor. It always detected rain and kept wiping even though it was blisteringly hot outside. After going back to the Carglass company three times without a fix, I decided to let the dealer fix the problem and send the invoice to Carglass.
So definitely check out the rain sensor, and the camera seating to. There is a metal clip/spring holding the camera snug in it's holder, if it is squashed flat the camera will vibrate and give you lots of errors regarding the pre collision prevention feature and it will make lane keeping drop out constantly.
You may also want to press the max defrost button, which should heat the camera window and wiper park areas. Then check the vehicle for open circuit codes. The defroster connections are made in the cowl below the windshield on the passenger side, in some cases those connections are not done properly which results in the defrost area is no longer working.
AlMelbourneFL
Al
Melbourne, FL
2023 Mach E
Retired s/w developer
Thoughts?
When they replaced mine, they connected to the car from their mobile app and used software to complete the analytics.
Colorado MME GT
Aurora, CO USA
2023 Mach-E GT
Retired Traveling Fool
I just had mine replaced by Safelite. They ran the calibration software on the test drive and sent me the collaboration certificate. So far, lane centering and BC work fine. I haven't seen the rain sensor issue.
