HEATING SYSTEM - Mach E Mustang
SuzieN
Suzanne
Detroit Mi
Ford Mustang Mach E
I am wondering why i am getting cold air coming out of the vents when it's on heat 76 degrees. Always something and they take so long to repair these cars !
AtomicInternet
SC
Focus RS, Mach E Premium
The heater in these cars is underpowered, but be sure your car is in the RUNNING position not just ACCESSORY ON position. Heat/AC won't run unless the car is fully powered on. That seems to be a large percentage of issues.
If you are DRIVING YOUR CAR and there's no heat, make sure the heater button is active in the HVAC screen. I can't imagine it not turning on if you select heat, but it's possible.
Heat button:
Ford Motor Company
Official Ford Account
Hi there! Go ahead and send us a private message with your full name and VIN, I’ll look into this for you. Thanks!
Set it to 85°F and press the AUTO button a couple times. Feel for heat coming out of the floor vents after several minutes. If it’s still not hot then you need service.
If your temperature is set to something below the cabin temperature it will blow cold in order to get the cabin down to the set temperature. Make sure your HVAC is set to a higher temperature than the cabin’s temperature. Of course, if it is cold enough outside the HV battery will get the heat first. I once got cold HVAC air while driving in a snow storm. ?‍♂?
SuzieN
Suzanne
Detroit Mi
Ford Mustang Mach E
thank you will do that!!!
SuzieN
Suzanne
Detroit Mi
Ford Mustang Mach E
where should I send it to? Your service department in Michigan is AWFUL - they keep the car days and give no car to use in the meantime!!! Please send me the email where I should send this to.
Go back to their message and hover over the name of the account (Ford Motor Company) then click on the “Start Conversation” button. ??
SuzieN
Suzanne
Detroit Mi
Ford Mustang Mach E
I did that - thank you!
