High exterior temperature warning
yubbie2
Houston
2023 MME Premium RWD
Just got home from a few afternoon errands. I’m in Houston, so it’s crazy hot out, but as soon as I pulled into my garage the car came up with a warning message “Exterior temperature high. Plug in vehicle when not in use” (or something like that). I looked at the display and it thinks it’s 130*F outside!! Yeah it’s gross and hot but it’s not that hot. Do I need to worry? Do I need to plug it in?
Ford Mustang Mach-E High exterior temperature warning IMG_2720
The car is suggesting you plug in. Whether or not you follow that suggestion is up to you.
yubbie2
Houston
maybe I should be more specific. Since the exterior temp sensor is clearly wrong, is it valid advice from the car?
If it’s hot, it’s valid advice. Mine tells me to plug it in all winter long due to the cold. But I never do.
Yes, the battery can be warmer than the air temperature due to thermal radiation from the ground in hot sunny weather. Plugging in will allow the battery to cool down.
In a hot climate like Houston, you should set your car to only charge at night from 7 PM to 12PM, and plug in as soon as you get home. This allows the battery to cool down right away, but charging won't happen until later in the evening.
canuck1975
Hamilton, Ontario
2025 GTPU Eruption Green "Incitatus", previously 2022 Select Cyber Orange
I've been in telecom for so long I often forget what my today job is!
Rebel! I'm keeping mine plugged in all the time. I park outside so am really screwed by the Canadian weather fluctuations.
Blue highway
Mach E Premium SR RWD
I bet it is that hot on Houston asphalt.
Heat is really not good for the battery, I'd plug it in.
Haydn12
Chandler, AZ
Mustang Mach-E, Toyota Prius Prime
The temp gauge on the MachE is really off. Wife said it was showing 136 degrees the other day. Our other car's highest temp was 122 on the same road. The temp in that car is pretty accurate. It was 119 on the day when it said 122 which would have been the extra heat from the asphalt road.
4sallypat
Pat
www.kudo-ume-farms.com
Network Tech
The temp sensor seems to be reading hotter temps when parked in the sun.
Once you drive off, the temps come down to realistic numbers.
yubbie2
Houston
So if the sensor says 130, but it’s actually 95-100, am I correct that I am not actually in danger of damaging the battery?
Correct, plug in when the air temp is above about 104°F.
You must be moving faster than 20 mph for several minutes before the temp will read accurately. In stop and go traffic it will not read correctly due to heat from the sun, ground, and radiator.
yubbie2
Houston
Great! Thanks for the clarity.
desiguy2447
Adam
Frisco Texas
2023 Ford Mach E Premium
I got the same message for the first time here in the DFW area (Frisco). The actual temp was 106F outside on Friday evening with the display showing around 111F. I plugged in the car once home and the cooling turned on in 50 seconds.
san
Texas, USA
2022 Mach-E GT; 2023 Mach-E Premium
If plugged in like you suggested but not charging until later at night, how does this help the battery cool down?
hybrid2bev
2026 Rally
The car can draw ‘wall power’ to run the battery cooling system.
