Hitch install uhaul
TheVirtualTim
Dearborn, MI
Killerkg
Kunal
Vienna VA
2021 Mustang Mach E Job 2
Finance
Here are the pics. I do think the stealth option is a good one as well, the only hitch is that you have to carry the hitch ?
There is a small opening in the back , not sure if I need a cover for that.
Ford Mustang Mach-E Hitch install uhaul PXL_20230410_164245746
Ford Mustang Mach-E Hitch install uhaul PXL_20230410_164055026
Ford Mustang Mach-E Hitch install uhaul PXL_20230410_164646186~2
Ford Mustang Mach-E Hitch install uhaul PXL_20230410_164256383
Ford Mustang Mach-E Hitch install uhaul PXL_20230410_164236999~2
Ford Mustang Mach-E Hitch install uhaul PXL_20230410_164500486
Ford Mustang Mach-E Hitch install uhaul PXL_20230410_164447562
MacherAWD
North Shore MA
Healthcare Software
Pics please when you can.
Here are a few pics, with and without the extension, trunk easily opens without contact, but does add a bit more wobble
Ford Mustang Mach-E Hitch install uhaul PXL_20230412_143315426
Ford Mustang Mach-E Hitch install uhaul PXL_20230412_143326643
Ford Mustang Mach-E Hitch install uhaul PXL_20230412_143414964
Ford Mustang Mach-E Hitch install uhaul PXL_20230412_143420103
Ford Mustang Mach-E Hitch install uhaul PXL_20230412_143429466
Killerkg
Kunal
Vienna VA
Finance
Same here. The trunk opens easily for me even with the bikes on the rack
MacherAWD
North Shore MA
Healthcare Software
Without the extension? That is nice. Mine hit with the new rack, I didnt think about buying one with a longer tongue. But the extension allows our highlander to also open the truck with the rack on.
Killerkg
Kunal
Vienna VA
Finance
Yes without the extension. The bike rack I have can hold 3 bikes, as long as I put the kids bike on the innermost rack, the hatch opens
steve.panse
South FL
2022 Mach E GT PE
Maybe it doesn’t bug others as much, and I’d certainly deal with the visible receiver if there were no other options, but I much prefer the invisible look of the Draw Tite Hidden Hitch For the 98% of the time that I don’t have the bike rack installed.
MacherAWD
North Shore MA
Healthcare Software
Agreed, from the back it looks good, but from the side looks almost like I have a tailpipe! Although from a higher angle it's not visible
kindofblue
Reid
Arroyo Grande CA
Grabber Blue Mach e Premium 11/5/22, '25 Lexus 45h+ PHEV
Hi all,
I got the UHaul hitch installed yesterday and am now thinking of how I could cover up the holes on either side of the hitch to keep dirt, snow, etc. from getting up in there.
My first thought is to cut the piece of plastic that they cut out in half and then somehow glue or attach it to either side maybe using construction double sided tape that I've used to attach the corvette mounting pucks for lifting the MME. I could probably attach one half with the excess inside of the rest of the plastic frame but am not sure how I would do the same with the other half when I can't get my hand up in there.
Your thoughts and suggestions would be most appreciated.
Ford Mustang Mach-E Hitch install uhaul IMG_1010
21st Century Pony
Martin
Arlington, Virginia
Hi all,
My solution pics are attached... used the OEM cut of the bumper cover, modded for my rear pull shackle, plus some H pattern rubber strips and safety wire to securely hold things together.
Ford Mustang Mach-E Hitch install uhaul 20230516_155534
Ford Mustang Mach-E Hitch install uhaul 20230516_155617
Ford Mustang Mach-E Hitch install uhaul 20230516_155516
Ford Mustang Mach-E Hitch install uhaul 20230516_143536
Ford Mustang Mach-E Hitch install uhaul 20230516_143514
Ford Mustang Mach-E Hitch install uhaul 20230516_154325
Ford Mustang Mach-E Hitch install uhaul 20230516_154315
Billyk24
William
PA
I had an Ecohitch installed at U-Haul today. A 4 flat wire was also installed. Total installation time was a little less than 3.5 hours. Biggest complaint was the removal of multiple Funk bolts/nuts to reach the 12V battery. I purchased the hitch and wiring prior to making an appointment and brought it into the location for installation. As seen in the photo, the hitch doesn't stick out. Recommended using a wireless Curt Echo Brake Controller if your trailer has brakes. Now to find a brake light to fit into the 2 inch hitch. U-Haul uses a unique elevated tire supporting ramping system to allow workers access under the vehicle. Here is the U-Tube video link: 2022 Ford Mustang Mach-E | U-Haul Trailer Hitch Installation (youtube.com)
Ford Mustang Mach-E Hitch install uhaul mach e hitch dec 2023  photo 2
Ford Mustang Mach-E Hitch install uhaul curt wireless brake controller
