How slow is 120volt outlet?
edharris
Mathew
Los Angeles
Mach E Premium
A couple newbie questions about charging...
I understand that charging from a standard 120volt outlet is much much slower. My route to work is only ten miles round trip so I'm wondering if I could still get by with a standard outlet and daily overnight charging.
1. Would an overnight charge still yield about 20-30 miles over about 12 hours?
2. Does it cost more to charge with a 120 volt outlet than it does with a 240volt outlet since it takes more time? Or is the energy used still roughly the same to get to 100% battery?
Kabish
2021 Mach-E Mustang
120v or Level 1 charging is super slow.. I used it for a while till I could get my level 2 installed. You will get about 2ish miles give or take every hour of charging. So if you are only doing 20-30 miles a day it would be pretty close.
Power is charged by kWh so regardless of Level 1 or Level 2 the end result of delivering the power to the car will be the same. Only time where a faster charger can save you money is if you are on a time plan. For example, it only costs me $0.09 from the hours of 12-7am. So I want a faster charge so I can get to 90% in that 7hr window. If I were to charge outside of that window, then it would cost me more due to the rate increase.
TuxToaster
Salt Lake City, UT
2021 Infinite Blue MME Premium ER AWD
Generally speaking, yes -- the average is ~3mi added per hour. But how much power is consumed for you to travel 30 mi depends a bit on the route taken, driving style, etc. but a ~25mi trip I regularly take usually uses up around 6-10% and I can usually put that back into the battery in roughly 6-8 hours of charging.
Someone else here can probably offer a better answer here, but the costs would generally be pretty similar since while it does take longer it's pulling less current. Though I believe 240V is generally more efficient but I don't know how much that would translate into cost savings.
About 3 miles of range for each hour on the plug.
Cost is about the same as L2 charging.
SAM
SAM
Central NJ
Premium MME4X Iconic Silver
I've been getting by on 120 since I got the car in June (too lazy to get an electrician). It consistently delivers just over 3 miles estimated range per hour plugged in. Mostly hasn't been a problem for me. One time I wasn't gonna get enough juice for a planned trip the next day, so I drove to an EA and charged to 80%. I will eventually get around to having L2 installed but it certainly hasn't been critical (no regular commute).
JamesInWeston
James
Weston, Florida USA
ordered 8-25-21: 2022 Ford Mustang Mach-E CalRt1
Risk Management/Insurance
Is everyone's 3-ish miles experience at 120v at 8 amps? Can the Mach-E be programmed to pull 12 amps at 120v? (like my Bolt?)
Bolt at 120v 8 amps = 3-ish miles. At 12 amps its 4-ish miles per hour of charging.
hybrid2bev
2026 Rally
Same as the others have said about speed of charging.
Cost would be about the same, unless you have time of use electric rates and you need to charge outside of those set hours (L2 would be advisable here to limit the charging time).
You don't want to charge to 100% daily and usually only charge to 100% if you're immediately leaving on a road trip. Daily charging recommendations are 80%-90% max to preserve the battery health.
I believe that the loss from the outlet to the vehicle is greater with 120 than with 240. Closer to 15% than 7%. Someone correct me that knows for sure.
I got around 2.8 miles per kWh.
It should be 12A as well.
Watts are watts. A L1 EVSE at 12A delivers a certain amount of watts and the Focus Electric or your Bolt can travel about 4 miles on that amount of energy. The Mach-E travels about 3.3 miles on that same amount
The Lightning will be even worse. 2.2 miles of range per hour of L1 charge maybe? I have the chart somewhere.....I will try and find it.
RobFitzgerald167
Rob
Chandler, AZ
First Edition Grabber Blue
It’s slow. I’m on a 120v charge right now, no 240 outlets available. Here’s my current charging stats (FE ex, northern IL… darned cold)
Ford Mustang Mach-E How slow is 120volt outlet? 0941648C-06D0-423A-8514-CA8A994866FA
ArthurH
Arthur
CA
Mach-E Premium AWD EX; Rapid Red
The difference in price can fluctuate quite a bit depending on your utilities' peak hours. For example, in our area during summer, peak hours of 5pm to 8pm is nearly triple the cost. You'll just have to plan around your time/rates, if that is a concern to you.
ADDZ71
Austin
Brevard, NC
21 MME Premium ER AWD (sold) 22 MME GT (Del 5/22)
Lithium expert
You can get by on the 120V and the occasional use of some type of faster charging. I would highly recommend getting some type of Level 2 charging where you regularly park. With your anticipated daily round trip and 120V charging you do not have any catch up room for the time when you decide to do some extra miles on a Sunday as an example doing holiday shopping. Let's say you drive 100 miles on a Sunday when you get to the following Friday you are still that 100 short since you have only recovered your daily commute. If you suggested that you had multiple days (work from home, retired etc) where you did not drive the car then I could probably get on board with only 120V charging.
Bill S
Winter Haven, FL
22 MME Prem ER eAWD, 25 Tesla M3, 64 Falcon Sprint
If you can drop a 240V off of your electric panel it will get much much better. Your mobile charger will plug into to it with its 240v adapter and BOOM, your alive. Closer to the panel, the lower the install cost. Easy Peasy.
MargaritavilleNH
NH
2021 Mach E GT 2025 Mach E GT Rally
Yikes, I thought my 80% charge to 168 miles was bad....I guess it's going to get worse!
