How To: Enable Power Meter on Non-GT Mach E
McSquashy
Josh
Massachusetts
Powertrain updates.
Bummer. Enabling the power meter was next on my FORScan to-do list.
AFAIK, my Mach-E received the latest powertrain update on 9/26. Guess no functional power meter for this guy.:confused:
AtomicInternet
SC
Focus RS, Mach E Premium
I'm all caught up with FDRS updates, including the powertrain/ABS ones from last weekened. I still have the power meter, and it shows power/regen when I'm driving. Is it possible I have a different Forscan config?
Built 04/23/2023 Premium RWD
Feel free to check my VIN to confirm I'm not missing something: 3FMTK3RM6PMA31903
Ford Mustang Mach-E How To: Enable Power Meter on Non-GT Mach E PXL_20241007_125544221
CarGuy11
Pittsburgh
2022 MachE4X Prem, 2020 GRSupra, 2016 Corvette Z51, 2024 Emira
Nice!! Great sign they fixed it!
Reicher89
Alberta, Canada
2023 MME CR1 (Star White), 2024 F-150 XLT 2.7L SCrew 5.5 BAP 18" (Oxford White)
I just did this on my 2023 CR1, but my entire right side is always fully "grey-barred". Does anyone know why this is?
Ford Mustang Mach-E How To: Enable Power Meter on Non-GT Mach E grey_bars
Did you disable the power meter before doing your FDRS updates? I believe that in the powertrain update thread someone suggested that. ??
AtomicInternet
SC
No Forscan changes before or after the update.
I even recorded this last FDRS update for giggles (Oct 3rd).
McSquashy
Josh
Massachusetts
How did you enable the power meter - by changing values in As-Built or turning it on in the non As-Built section?
Admittedly, I'm new to FORScan and don't know if there's a difference in the method of making changes with FORScan, but maybe someone more experienced can chime in.
Maybe because you’re RWD?
byoungblood
Bart
Berryville, VA
2012 F150, 2007 Mazda 3, 1999 Jeep Wrangler
FWIW this mod seems to be broken with latest round of updates - it now shows jail bars on the right side of the meter. I am only visiting this thread again to remind myself how to disable the power meter.
I don't believe anybody has figured out how to fix this issue.
This happened to my CArt1 back in August/September when I went in for the 1 pedal drive fault TSB.
McSquashy
Josh
Massachusetts
Just enabled the power meter in my '23 Premium and it seems to be working just fine.
Admittedly, I haven't had the chance to drive with it yet, but I didn't see any gray bars. I'll update if anything changes.
McSquashy
Josh
Massachusetts
Happy to report back that the power gauge functions normally!
2023 Premium 4X ER with the following OTA updates:
ECG-24.2.4.9
23-PU1103-NAT-VCE (6.2.1)
6.3.0 (Not Completed)
24-PU0121-FTDI-FX
24-PU0119-DC-CHG4
24-PU0301-BLM-PE
23-PU1024-6CH-AUD
6.7.0
23-PU0630-RGT-PLO
23-PU0110-RAD-PS
23-PU0907-RAD-ON
ECG-24.2.4.10
6.8.0
ECG-24.2.4.10.2
6.14.0
23-PU0725-CLM-FX
24-PU0102-CHG-SUGX
24-PU0105-CMR-FX
PMA-24.204.8.27 (BlueCruise 1.3)
ECG-2.5.6.2
23-PU1113-UNX-DC
4wheeldog
7200' elevation New Messico
2024 Premium AWD Extended range
Retired a long time
It would be the equivalent of a tachometer. I’d want it so long as we don’t get any grey bars. If we would, I’d rather not see it!
A week or so after I got my 24 premium I was curious what RPM the motors turned at speed. First Google answer was “About 2000 rpm at 60 mph”. Second was about 6100 rpm (I didn’t memorize the exact value) at the same speed and a “Redline” of 13,000 and change. Made me feel like I was driving in a F1 car but quieter.
Reactions: ARK
