Blue highway
- Steve
- Oct 15, 2021
- Oregon
- Mach E Premium SR RWD
When I changed the battery, I followed these steps from the thread above:The dealer is supposed to reset the BMS when they replace the battery, but in a lot of cases they fail to do that. If you don’t have a way to check, I would recommend going through those steps to reset the BMS yourself to make sure it gets done.
- turn MME 'off' once LVB has been charged to 100%
- Press the START button without pressing the brake (ACCESSORY mode)
- Flash the high beams with the stalk 5x
- Press the brake pedal 3x
- Battery icon on instrument cluster should flash 3x to indicate reset
- Turn OFF the car
- Turn OFF Fordpass and Bluetooth if you use PAAK so car-phone are not communicating
- Park the vehicle undisturbed for 6+ hours to allow the BCM to verify the battery SoC and quiescent load
The battery icon does not flash...
Are the steps above correct? any ideas?
