How will I know when the 12 volt battery needs replacement?
Hammered
SE US
2022 PB F150, MME GTPE
That’s moving the goalposts….
All of the new vehicles come with AGMs, quoting experiences with FLA and SLA isn't relevant to the issues ongoing with AGMs.
I can accomplish the same solution with a Battery Tender. I would never waste that kind of money nor add that weight. Glad it worked for you.
I only picked up 3lbs
khbkhb
Keith
Cherry Hills Village, CO
Mustang Mach-E, Stromer ST-1, Cattrike, Mazda CX9
Computer Geek
Will I get a warning when my LV…
I suggest an aftermarket tester like https://a.co/d/aQiCjZJ makes it easy to track ...in "accessory" mode " you should see well over 12v. In drive mode 13-14v
A load tester can give a higher quality answer but with the buried terminals in the machE not super handy. 12V Car Battery Tester, TOPDON... https://www.amazon.com/dp/B0B5T7212M?ref=ppx_pop_mob_ap_share
With a Bluetooth OBD2 dongle and an app like "car scanner" you can get the 12v info from the machE's internal monitor
OrchidMania
Miami Beach
Grabber Blue Premium ER
I got this message from ford psss today. Last time st dealer was February for HVBJB. Car is 2 years old I’m on S florida. No garage so have I been in red for 3 months?? Advise please
Ford Mustang Mach-E How will I know when the 12 volt battery needs replacement? IMG_1673
AtomicInternet
SC
Focus RS, Mach E Premium
Your battery is at the 20 yard line. You need to kick or run in for a touchdown.
Ford Mustang Mach-E How will I know when the 12 volt battery needs replacement? 1714771945271-f
bshaw
Boston, MA
If your car is only 2-yrs old, then I think a failing 12V would fall under the 3-yr warranty (unless you're over on miles)? Ask your dealer if its covered under warranty and if yes, then do it.
In my experience, the 12V batteries all seem to have about the same lifetime -- 3yrs is short and 5yrs is exceptionally long. In a warm climate, I don't know why it would be near failure after only 2-yrs.
Teslaeata
Nottingham, England, UK
I’d follow the maker’s and dealer’s recommendations and have it changed, under warranty if possible, if not I’d pay for it (mine if required, not yours?).
They’re not expensive.
Your experience proves the value of taking car in for its routine servicing on time & other recommended maintenance, I’d ignore all the claims of “all they do on a service is swap tyres around & change cabin filter.
They check things like the battery, go underneath for an expert examination and do safety & general checks-it’s a preventative thing and worth every penny ??
Enjoy the MMe Experience?
OrchidMania
Miami Beach
Only have 8500 miles was planing a 200 mile trip this Sunday for 2 days Hotel has charger so can keep it plugged in. Or take husband ice
There is no indication in the vehicle data that the 12V battery is bad. It does not need replacement at this time. I'm not sure why that message was triggered, but it could be dealer fundraising.
OrchidMania
Miami Beach
Thank you. Was hoping from a reply from you. Would you drive to car from miami to cocoa beach without worries? Also should I charge up L1 or L2 before trip or doesn’t matter. Thanks again !
Recommendations for an odb2 dongle? Going to buy one today
Falcon53
Duke
Vancouver, WA
2021 Mach E GT, 2017 GT350
Pharmacy Software Development
What is the cost of replacement?
