Humming noise when AC is running
PCPilot
Frisco, TX
2021 Mustang Mach E, FE
I just noticed this today, but I'm hearing a fairly loud humming sound coming from the vehicle, and it seems to be tied to the AC running with the fan speed on or close to high. We run it in Auto mode. Has anyone else noticed this? Not sure if it's a normal thing, as we just recently started getting warmer weather, but I definitely haven't heard anything like it in the 4 months that we've had the car. Thanks..
yes, the A/C compressor and fans will be audible. On an ICE the engine is making so much racket already you don't generally hear it, but since there is nothing else making noise it will be more noticeable.
My ā€˜69 Cadillac was so quiet that the replacement A/C compressor was audible as a sort of gravelly noise when the clutch was engaged. The original compressor was quiet. Not sure that your much more modern electronic compressor is at fault Since you say itā€™s when the fan is on or near high. I would be more inclined to think that it is related to the fan or the duct work right near the fan.
Crilly
Dale
Hartland, Wi
I think my Mach e came with the dashboard vents closed. Make sure they are open.
PCPilot
PCPilot
Frisco, TX
Confirmed they are open, and the noise is actually heard outside the car.
Cagedcar
AZ
Mach E
So interesting enough yesterday we started hearing a crazy noise outside the car last night. When you turn on the AC there is a loud winding noise and the higher the blower is set the louder it gets. Honestly sounds like it's going to blow. Ours has been extremely quiet even with that on besides a normal fan sound so it's interesting that this just happened. Did you get the OTA update I just got mine yesterday? Not sure if its connected just curious but I'm taking it in tonight.
Orangefirefish
SY
N/A
I have that buzzy compressor sound too, not saying itā€™s normal but itā€™s loud outside and audible inside, I donā€™t know to what extent itā€™s normal, just have been too lazy to go to the dealer even though I can see their sign from my house. ? Iā€™ll try to make a quick vid of it later.
Timelessblur
Tyler
Austin
Software Developer
for me I noticed some extra noise is from the front louvers opening up and then the cooling fans running.
Mind you on an ICE car the radiator fan running is hard to noticed as the engine makes a lot more noise to cover it up. On an EV well there is no engine to cover up those little noises. On my Honda Crosstour when I turn the car off on a hotter day I would hear the radatior fan going at full power for a few mins as it is cooling off the radiator before shutting down. That was loader than you would think but if the car was on well the engine covered up all that extra noise.
peoples1234
NC
2021 Mach-E FE GB
Yes, I have a noticeable noise. I can also feel the hum through the steering....which I think is weird. But it works, so I assume it is normal.
VegStang
Leo
Silicon Valley
Volvo C40 Recharge, 2021 MME
The compressor noise on our previous Mercedes B-Class EV was such a loud, low rumble the dealer replaced it under warranty- the replacement was actually slightly louder. The MME is much quieter. ;)
Finkerton
Boston, MA
MME FE
Yeah it's super loud outside the car and super buzzy. And I also can feel it a bit through the steering. Unsure if it's normal and expected or not.
zhackwyatt
The C-max also had a very noisy, buzzy compressor. The MME is a little quieter. I guess it's the electric compressor they used compared to a belt driven one.
Fusionblu
Ford Mach~E, Kia Telluride, BMW 335i
IT fiddler
I have the exact same problem. I can feel the vibration in the steering. The noise is pretty loud outside the car.
