HVB Charge limit setting
DAC17
CT, USA
2023 Mach-E Premium, 2023 Chevy Bolt
Sorry to be clueless, but I can't find the method for setting the Mach-E's charge limit to 80-85%. Thanks for the info.
TJSparky
Travis
WA
2023 Mach-E GT Performance Edition
Go to Charge Settings and click on the edit button to create a charge schedule. Part of that schedule allows you to set a limit.
I keep mine at 80% and charge 20-80%. We use it mostly for local drives. If we are going on a long trip I will charge to 100% first night. I only charge to 80% if going to a "Charge Station"
DAC17
CT, USA
Thanks!
JohnFoxeSheets
San Francisco
johnfoxesheets.com
One thing to note is that you have to set it for each charging location.
And another thing to note is that you cannot set a charging location until after you've charged there once. This means that the first time you charge anywhere, your car will charge to 100% unless you stop it first. WhyTF did Ford do that?
No. One. Knows.
silverelan
Seattle
There’s no universal charge limit in the MME. It’s silly. I think there’s one in the Lightning though.
The Lightning has the capability to set a one-time limit that applies to your next charge regardless of location, but there is no permanent, location-agnostic limit.
I believe the Lightning has a pre-set 90% DC charging limit. The Mach-E doesn't have that.
Is that for L2 or DC? Or both?
Edit….from the Lightning manual:
Ford Mustang Mach-E HVB Charge limit setting IMG_0644
DAC17
CT, USA
Wow. Guess I opened a cam of worms here! Funny that my Bolt is so simple to set a limit for.
