mads0100
Minneapolis, MN
2022 MachE PE AWD
@Azjrider,
Thanks for the install instructions. Bought it before the 4th...installed today. Pretty easy following your guide/the setup guide. I only tried out the 'default' settings and took a quick spin... everything was working well.
Thanks again for posting good instructions for all of us. I appreciate it.
ScoobyDoo27
Brandon
Utah
2024 Mach-E Premium AWD
I just did my first 2 drives with 4.0 (110 miles) and it was a pretty rough go. The car ping pongs like crazy on straightaways and can barely take a curve without throwing the "turning exceeds steering limit" error. I am using the FoF Liquid Crystal model as directed.
It's hard for me to make out what is what in the settings so I'm not sure how to tune it (or if it's even tunable). Is it suggested to just go back to 2.1? I really like the UI improvements but 4.0 makes the comma unusable for me.
AjzRide
Alan
Houston
RR 2021 MME Premium RWD
Eng
Please upload a route I can analyze. This makes no sense based on feedback from everyone else.
ScoobyDoo27
Brandon
Utah
I don't see a QR code anywhere to link it with comma connect. I need to reset my device and install openpilot for the QR code to appear?
AjzRide
Alan
Houston
Eng
No, you have probably already done it and forgot about it
try going to connect.comma.ai and logging in with apple, google, or github and see if your device is there.
ScoobyDoo27
Brandon
Utah
I’ve never hooked it up through connect or accessed it through a web browser. I bought the device used so I’m guessing that’s got something to do with it. Is there not somewhere to just log out and re-log back in?
AjzRide
Alan
Houston
Eng
No. Unfortunately you will have to track down the previous owner and ask them to go remove it from their account.
if that fails we would have to point you to a 3rd party server.
AjzRide
Alan
Houston
Eng
for now just take pictures of all your BluePilot settings. Maybe something will jump out at me.
ScoobyDoo27
Brandon
Utah
Holy s!#t, seriously? So the previous owner has access to all my drives/data? What a privacy nightmare and kinda scary to think about. I'll message the previous owner on eBay and see if they will unlink it but I don't have high hopes.
I've attached the photos of my settings. All of my settings are default except I changed model path color to orange and I turned on the settings that make it look like bluecruise.
Ford Mustang Mach-E Installing Comma.ai / OpenPilot (BlueCruise alternative) IMG_0096
Ford Mustang Mach-E Installing Comma.ai / OpenPilot (BlueCruise alternative) IMG_0099
Ford Mustang Mach-E Installing Comma.ai / OpenPilot (BlueCruise alternative) IMG_0093
Ford Mustang Mach-E Installing Comma.ai / OpenPilot (BlueCruise alternative) IMG_0098
Ford Mustang Mach-E Installing Comma.ai / OpenPilot (BlueCruise alternative) IMG_0094
Ford Mustang Mach-E Installing Comma.ai / OpenPilot (BlueCruise alternative) IMG_0092
Ford Mustang Mach-E Installing Comma.ai / OpenPilot (BlueCruise alternative) IMG_0095
AjzRide
Alan
Houston
Eng
turn off advanced lane positioning. Let’s see how things change.
ScoobyDoo27
Brandon
Utah
Will do, I'll report back tomorrow morning after my drive to work. I'm not able to test it out tonight.
AjzRide
Alan
Houston
Eng
also if it didn’t recalibrate after the update, trigger one of those
AjzRide
Alan
Houston
Eng
I know I tested and developed a tuning profile on my wife's MachE, because I can see it in the code. But I, too, had a terrible drive this morning in her car when I went out to test it. I am analyzing the logs today to try and figure out what is going on. I tried turning off all of BluePilot tuning and drive on stock OpenPilot and it was still moving around the lane.
ScoobyDoo27
Brandon
Utah
Glad you are able to recreate what I am seeing. Turning off the advanced lane positioning setting did help a bit this morning on my drive to work. I was able to take slightly sharper curves but it did still give me a bunch of the "turning exceeds steering limit" warnings that I never did get on bp-2.1. The ping ponging on straightaways did seem better too but not completely gone. I don't know if this is related but the comma kept freaking out and throwing "radar error: restart the car". It would make a ton of noise then just randomly go away, then come back again in 10 minutes, then go away.
The seller I purchased the comma from did reply to my message and said they removed the device from their connect account. I will (hopefully) connect it up this evening and I can share a route if you are still interested.
