Is 22S41 Weld Issue A Problem For Me?
Paddler
Doug
Richmond, Virginia
Mustang Mach-E Premium w/Ext. Range Battery, RWD
I only recharge my MME at home with a JuiceBox 40, and normally to 85%. Before two short trips I went to 100%. I have no intent to ever do a quick charge, and I am not an aggressive driver. I have not received the OTA software update for 22S41 but plan when I take the MME in for service/inspection in March to have my dealer perform the update. Am I pressing my luck by not having the update done sooner?
Get it done. It’s cheap protection against the a stop safely now failure and should allow you to drive the car to the dealer for repairs should it ever happen to you.
AKgrampy
Fairbanks, Alaska
I am in the same boat and am going to take the same approach in that I will have the software installed by dealer during the 10,000 mile check up if I do not have the OTA by then. I only drive around town so if something were to happen it would not be that big of a deal. If I did longer distances I would get the update right away. Just because we do not do DCFC and charge at home does not mean we will not have a failure. Passing on the highway and big hill climbs would be my concern and for now I do not have those conditions to deal with. (And no WOT’s on our icy roads for next 4 months!)
RMoore
Rob
I asked this in an earlier thread but didn't get a response: if we haven't received the recall update via OTA at this point, does that mean we never will? I never got any message saying download failed or similar, and I've received all the HVAC updates via OTA up to 3.6.1.
hawkeye3point1
NH
Does your Ford.com dashboard indicate the Recall is still outstanding? It is possible the OTA did occur but notification failed.
I can tell you this, if 3.6.2 installs in your car it will be up to recall complete status because the same modules are reprogrammed by it. I know this because I had 22S41 done by my dealer in July, they failed to register it correctly in FDRS though apparently because up until the other day my dashboard was still showing it outstanding and I even received the snail mail letter from Ford saying I needed to get it done. Then I got 3.6.2, next thing I know the Recall cleared on Ford.com. Two birds with one stone.
RMoore
Rob
It is showing as "recall incomplete" on my Ford.com dashboard (though I can't find it anymore on my FP app). So it doesn't look like I received it. I'll reach out to my dealer to set something up for them to do it. I would have preferred getting it via OTA but not sure if or when that would happen at this point. I guess I can also call Ford CS and ask.
