JuiceBox 40 Charging Faults - Please help a new owner!
SaraFed13
Sara
Jersey Shore
2023 Premium ER/AWD, 2017 F-350 6.2L, 2012Acura TL
Every time I plug my new MachE into my JuiceBox 40 (plug in, not hard wired) charger, I get a notice from the Ford Pass app that the charging was stopped due to a fault in the charger. I get no fault codes on the app that help me troubleshoot this. I called the EnelX customer service and they said it's a problem with the car. I verified that I have no scheduled charging session times. She walked me through resetting up the charger as a new charger (unplug and re-plug in, go through the "install new charger" sequence of connecting to WiFi). I can't imagine I really need to be doing that for every charging session, but I can't figure out where to start with troubleshooting and fixing this! Thanks in advance for any suggestions!
Scooby24
Olathe, KS
'25 BMW i4 M50; '25 MME GT
Healthcare IT
Being plug in you should probably check out the 14-50 receptacle to make sure it was an industrial outlet utilized and it's not already burnt up.
flapjake314
NYC
Mach-E Select AWD
are you saying after you reset the charger it worked? but then the next time you tried it didn't work again?
sounds like the charger to me...
Reactions: SWO
SaraFed13
SaraFed13
Sara
Jersey Shore
Yup! That is exactly what's happening!
DevSecOps
Todd
CISO
Do you get the same error with the Ford Mobile Charger?
This is the post you should be focused on. Try with the included charger and see if it works - process of elimination. If the included charger works, then it's the JuiceBox. If it doesn't work, then it's the car. That's what you should be focused on trying.
Richard L.
Richard
West Babylon NY
2021 Mach E First Edition Grabber Blue
Before you reset the JuiceBox is it beeping? If so, note the number of beeps and pattern.
TheVirtualTim
Dearborn, MI
Are the plug connectors on both the car and charger clean?
I stayed at a hotel last year that had four of these chargers. One didn't work. Another EV owner mentioned they have a JuiceBox and the connectors can have a loose fit that causes a problem -- although in his case (he had it for years) he attributed it to wear.
mbrownwvu
Cincinnati OH
2021 Mustang Mach E First Edition AWD (Grabber Blue)
I had a Juicebox charger for 2 years with no issues. When they forced migration to their new app, I had nothing but problems including what you are describing. After many call to Juicebox customer service, my box finally gave a 5 beep signal and it had to be replaced. Since then, things seem to be working. Long story short, I would bet this is a Juicebox and not a Mach E problem.
SaraFed13
SaraFed13
Sara
Jersey Shore
No beeps that i noticed, but will listen for this in the future!
SaraFed13
SaraFed13
Sara
Jersey Shore
Thnaks! Somehow I hadn't thought about this, but definitely makes the most sense in the way of troubleshooting. I will try this the next time I charge!
SaraFed13
SaraFed13
Sara
Jersey Shore
I appreciate this for future travel issues. In this case, I really don't think it's a cleanliness/wear problem. Car and charger are less than a month old. Car charge connection has't been opened outside the garage. Same for charger plug.
ArthurDOB
Arthur
High School Teacher
One more thread that’s making me glad I’m not getting a JuiceBox.
kennethjk
Ken
MME Prem. EB 4WD, X3, IX50
Although a different issue, I had a juicebox and the plug was too hot to touch, over 133 degrees and that was only after a few hours not 7. they tried to tell me all was ok.
finally spoke to someone who had some common sense and they sent me a new one. Now plug is ok to touch even after several hours of charging.
bottom line is follow up and if Ford Charger is ok demand a new one from Juicebox
