Knocking noise
Alaw
Ayrika
Chino
2023 Mach e standard range
Legal assistant
I hear a knocking noise when I hit the accelerator pedal and lift my foot off of it. Anyone have this issue? Got my vehicle on April
bshaw
Boston, MA
Look in your drive settings to see if you have propulsion sound turned on.
Mine recently turned on by itself and I wasn’t expecting that.
Where does the noise seem to originate? High? Low? Front? Back? Left? Right? ??
Ford Motor Company
Official Ford Account
Hi Ayrika. Can you send us a DM with your VIN and dealership info? I can look into this for you.
AlphaIOmega
Zane
Boise, ID
'21 Premium AWD EXT
Instructional Technologist
I have this same issue, and its been at the dealer for about 4 weeks now. They couldnt diagnose the issue, and decided to fix the TSB for the CV Axle. Supposedly I get it back today, but my B2B warranty expires when I drive it off the lot since I dropped it off with 35997 miles.
Does it sound like a click, or like an aching sound coming from the back?
hybrid2bev
2026 Rally
Ford Motor Company
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
Jack Roberts
Atlanta
Mach e GT
I am going to have my dealership check mine when I go in for 10,000 miles service in 900 miles. I get a knock on acceleration and stoping. It sounds like it’s coming from the post between the driver front and back door where the seat belt comes from.
Alaw
Ayrika
Chino
Legal assistant
Jferrari427
2023 Mach-E Premium Extended Range RWD
Knock, knock. Who’s there?
Have you tried higher octane electrons? ?
Neil4Real
I believe if the issue is brought up prior to your warranty expiring, they'll still honor the warranty on it. Make sure to discuss with your dealer that if this fix doesn't work, they'll still keep trying.
hybrid2bev
2026 Rally
Higher octane a.k.a. premium electrons (made from solar or wind energy) are less likely to cause early motor rotation issues.
Also this and the prior post are satire about how higher octane motor fuels help prevent premature ignition in ICE, known as engine knock.
