LFP battery vs. NCM
Dsirois
Daniel
Mach E (pending)
Considering an MME premium with choice of standard range vs extended. Are LFP batteries better because you can actually charge to 100%. Plus standard range LFP are $7k less than extended range. Help me decide
Dsirois
Dsirois
Daniel
Mach E (pending)
LFP battery = charge to 100% = 250 mile range
Extended Range battery 320 mile range, BUT recommended max 80% charge = 256 miles
Seems pretty close to me. What am I missing except for $7k?
Rt1AWD
CA
MME CARt1 AWD
I thought the recommended threshold is 90%
MellowJohnny
Christian
YYZ
Solution Architect
LFP is also affected more than LiOn by the cold. But as long as you're in the warm part of Florida should be a wash :cool:
Your range comparison is flawed. All batteries can be charged to 100% for a trip. And, regardless of the type, going from 80 to 100% on a DC fast charger takes as long as going from 20 to 80%.
Dsirois
Dsirois
Daniel
Mach E (pending)
Thank you for the input. This is certainly a learning curve. I don’t see the benefit of ER for $7k as I will mainly use for local driving in Central Florida. Maybe one long trip per year which I’ll have to plan out.
Rt1AWD
CA
MME CARt1 AWD
Even at 90%, I'd gain only 38 miles with the extended range.
It is totally Ok to charge to 100% once in a while. It is just not recommended to do it regularly and on fast charger
So for everyday use you have 288, which is more then enough. But if you go to some trip you can use all 320 miles. With LFP you don't have this option. That is basically it.
In your use case, SR is fine.
Rt1AWD
CA
MME CARt1 AWD
Another advantage is that theoretically you will be able to use your car longer considering the natural degradation. For example when your ER battery gets to 70% state of degradation you'll still have 224 miles
On the standard range you'll have only 175 miles
MacherAWD
North Shore MA
Healthcare Software
We live in New England, almost all road trips are under 2hrs, we do longer, 5 hrs or so, twice a year. SR AWD 21 for us, 220 miles, handles all our needs. SR Litium ion battery.
Dsirois
Dsirois
Daniel
Mach E (pending)
Is the SR less likely to be affected by the HVBJB issues?
what is your range at 100%?
Scooby24
Olathe, KS
'25 BMW i4 M50; '25 MME GT
Healthcare IT
If you need the extra range you're not charging to 90%, you're charging to 100%. The extended range battery gives you an additional 60 miles.
There's no point in comparing the NMC battery at 90% versus the LFP at 100% because you're not going to use all the range at 90% in a single day.
If you were, you'd definitely want the NMC.
But if you don't see a justification for it, you don't need it so don't buy it.
HGxxx
Harish
New york
Fusion energi, mach e premium standard range
That's been the case with the NMC chemistry that Sr pack is less affected, but I don't think anyone knows about the HVBJB with the LFP pack. I mean all 23s should have the new less failure prone part anyway.
