Locked Out, 12v battery isn't dead.
Ghost Ryder
LA
Tesla MYP, 22 GTPE
This brings up and interesting idea. How hard would it be to add a simple mechanical release and run it to the front access/bumper? Seems like it should be relatively easy to do.
BnT_MachE
BnT_MachE
BW
Denver, CO
Mach E Prem AWD ER
Right. Or have an actual working key in the fob and one mechanic lock on the driver's door just in case... but this could never happen, right, no one could get locked out???
santa fe,nm
www.envirokarma.org
Solar Sales/install
My guess is the 12v is dead enough to not power the modules in the car but not so dead that the frunk jump points are active.
mmmm.... OP said door pillar codes lit up. Best bet I think is to get door unlocked with pillar code, then diagnose the rest via ODB2.
if OP set a custom code, its probably best to try both what he set, and the factory code. If factory code is not accessable, Dealer can probably get it from Ford with VIN.
AKgrampy
Fairbanks, Alaska
He did state pillar did not work and factory code was suggested but unsure if attempted.
zvez
chris
ga
did dealer give you any insight yet?
santa fe,nm
www.envirokarma.org
Solar Sales/install
tomking29
Tom
Mustang Mach E
Finance
It’s quite humbling to stand there in a parking lot with no access to your car. It really made me miss having a physical key to at least get in the car.
BnT_MachE
BnT_MachE
BW
Denver, CO
Mach E Prem AWD ER
so, your dealership has the car now, and they have been unable to get help from Ford to get in?
bizarre!
maybe the BEV team @Ford Motor Company can jump in on this one to speed up the process ? try emailing [email protected]
It has been escalated through a contact at Ford, but still no response from the dealer.
BnT_MachE
BnT_MachE
BW
Denver, CO
Mach E Prem AWD ER
Enable notifications in FordPass when the doors are open. Unless it's broken you will know when they opened the doors.
That is a good idea. This issue on my side is, since the the day after it bricked, Ford Pass has not connected to the car. If they get the doors opened and system reset, that should reconnect again I hope.
