Locking door with touch lock button
Holding finger on the icon does not help, tried that.
Have not tried 7-8 / 9-0 option (will give it a try tomorrow), but all these other ways work fine including walking away. I am just hoping I can find a way to use this touch lock button as it seems most convenient to me. Again, it works too, just after some weird delay or a few tries.
If the driver's door is open, the internal button will lock the doors after you close then. Pretty silent. If you have the fob in your pocket, you can't then check by pulling on the outside handle as that unlocks them.
SpaceEVDriver
Planetary Science
Page 81 of the 2022 manual:
My experience is that I need to hold my finger on the lock button for a moment or two.
The next several pages discuss the keypad and its uses.
Ford Mustang Mach-E Locking door with touch lock button Screen Shot 2022-05-08 at 21.25.15
Kabish
2021 Mach-E Mustang
I think its the typical PAAK issue and updates.
My car for the first 6 months would NEVER lock with that button. Then all the sudden one day I accidently hit it somehow and it locked. Now I would say it locks without much issue as long as I do it very promptly after getting out of the car. I would say 1 out of 10 times I'll have it not work, been using it pretty regularly the last two weeks. One oddity for me, I find it works better if I slide my finger down. That said, its going to scratch the hell out of the panel doing it that way unless you keep your car spotless.
Not too sure why Ford had to put authentication to lock a door..... I feel like that is what causes the majority of my issues. PAAK is still not in its prime time, its WAY better than what it was, but its still a buggy mess.
SpaceEVDriver
Planetary Science
I don't use PAAK. After reading about needing to keep my finger on the button for a moment, I've had 100% success rate with the fob.
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
I’m on my 3rd Mach-E. Wife has one. I had one. Sold it and bought a GT. Across all three, that lock icon on the door pillar has NEVER ONCE worked for me. But the 7-8, 9-0 button combination, conveniently located just above the faux lock icon has been flawless.
TruWrecks
Oregon
Mach-E Star White Premium AWD Ext (Ghost Stallion)
I use the touch lock all the time. Sometimes I need to press it twice.
Chuck
Chuck
SoCal
Mustang Mach E 2021
Sorry, can't help you. I've never used the lock button, I only use the walk away lock feature.
buzznwood
california
focus st & GTPE
+1 to the lock button being flaky to the point I gave up trying to use it and just rely on the walk away feature and the horn honking. I tried to give it the benefit of the doubt for the first month of ownership but found I was spending more time resorting to using the keypad double button method.
Gave the the passenger side a go just to make sure something wasn't up with the drivers side button, but same success rate or rather lack of. I will give ford for the implementation on my Focus a 10/10 while I will give the one on the mach-e a 1/10 as it is that bad in comparison.
circle11
'22 Mach-e Premium
Something else I realized today after looking into this: when I get out of the car and close the door, the keypad is lit. It stays lit for maybe 10 seconds. During these 10 seconds the lock icon never works (but 7-8/9-10 combination does - thanks for that advise). Once the keypad goes off and is not lit anymore, the touch icon starts working. At least this is how it seems to behave on mine. Is this by design? If so, this design is not very well thought thru (understatement!).
TGIF
IA
When I first got my Pacifica I was convinced the lock buttons didn’t work. Turns out they just needed to be pressed for a second to work. I was punching them too quickly. You might see if that works.
Thunderbuck
Brett
Whitehorse, Yukon
2023 Mustang Mach-E Premium
IT Tech
I usually like the walk-away feature, but if I'm parking at night I don't want to disturb my neighbors with the horn blast. I've found the lock icon to be hit or miss (likely Paak issue) but I'll try the 7-8 and 9-0 button trick. Thanks ?
JohnnyForensic
VA, US
Digital Forensics
If you’re using PaaK, make sure your phone is reasonably close to the door when you press it (or the open button, for that matter). If my phone is in my front left pocket as it always is and I have my body turned away from the car, neither button works reliably. If I have it in my hand that’s pushing the button, it works almost every time without fail.
Ford Motor Company
Official Ford Account
Sorry if this has been asked before. I just got my Mach-e about 10 days ago and brand new to this forum. Love it overall but still trying to work through some little hiccups.
When I arrive to my destination, turn off the car and get out, I like to lock the car using the little lock button on the door located right above the door release button. The problem is that lock button never works from the first touch. It works eventually, but I have to push it like 5-10 times for it to work for several seconds. Maybe there is some kind of time delay feature? I don't think the button itself is defective because all the lock buttons on all four doors behave the same. Very annoying! Would love to get it to work with a single push.
BTW, I was shocked to see the numeric touchpad on this car. I should be able to lock the car with that lock button, and it unlocks automatically with door release button given I have the key in my pocket. What exactly is the purpose of the numeric keypad?
Thanks in advance for your help!
Hi there! Can you send us a DM with more information? I’ll see how I can assist on my end. Thanks!
JmanMachE
Jerry
Needham, MA
2021 Mach E Premium AWD ext. range
Please try this and let us know if it works - it seems to make a difference (after going crazy trying to figure out what I was doing wrong) though it may sound crazy. When you stand near the lock button, align the key fob vertically with it first and then press lock. Only a light press is needed for a short (under a second) duration. Same for unlock issues.
Update: I saw the post about being within 3 feet - that correlates with my advice as I almost always have the fob in my pocket and probably would be just out of range…
Chuck
Chuck
SoCal
Mustang Mach E 2021
I think it need only say "Bluetooth connected" on the Ford Pass app for the PAAK to work. In my case the phone can be in my pocket and when I get within about 10 feet of the car the tail lights light up when bluetooth is connected and I'm good to go. My phone doesn't need to be held by me for this to work. I suspect each phone model will be different.
