I was thinking the early v8's (before my time) were likely over designed and under utilized at the beginning also. As long at the hardware is sound with no major defects. I am not good with getting 70 KWh usable for the 100 KWh I anted up for but that is a dead horse and well known here. More complains always gets more results but one guy maybe not. We all know what we are getting and should expect (limitations and all) and should not expect miracles beyond what we have seen. Only two things and both can be tweaked so there is hope if no hardware problem. All good; be happy.I wasn't trying to be negative, but when I look back at it, it looks that way.
I am happy with the pre-production cars. I don't want to have high hopes for a bunch of changes when Ford is trying hard to push out all these cars to meet demand.
I had a computer chip fail in a first-year Prius, and they made the car a Lemon because they couldn't get a chip to fix it. And the car still drove just fine!!!
*I originally thought 6-months on the above time-line. Maybe I should keep it that way. I see how there are some people (not those reading this) that have unrealistic expectations and will be complaining loudly in a couple of months of driving.
** I'm even happy with the 11kW at "80%".
Well, the 22-40 minute stretch looks good. Peaking at ~110 kW and gradually tapering to ~80 kW. That's all good. Maybe even slightly ahead of expectation for that part of the curve.From a Norwegian test...![]()
Reference please. It is that drop at 41 minutes that is the only problem for me and it looks like it could be software correctable if the hardware can handle it? Starts at 20% soc and take around 40 minutes to 80% so 40min/60% * 80% * 1.25 or about an hour to 100% (as long as we can get to 88 KWh useable once in a while). The whole curve may be able to be software tweaked over time? Hoping for a quick software fix for sure. Ford had to have designed/tested DCFC at many stages during design, preproduction and production so it would be really weird at this stage to have a major problem. "Poor Norwegian's" was the quote? We hear you here in Canada.From a Norwegian test...![]()
They did start cold...that mostly explains the curve, the tapering at 80% is intentional and in the manual, you are not supposed to be FAST charging beyond 80%!Well, the 22-40 minute stretch looks good. Peaking at ~110 kW and gradually tapering to ~80 kW. That's all good. Maybe even slightly ahead of expectation for that part of the curve.
But the 0-22 minute stretch is very poor. Seems to suggest it probably started cold and took a looong time to warm up?
Hopefully they fix that in the production units.
I just read the article it came from in the other thread. Good to confirm it started cold. But 22 minutes to warm up is a lot longer than I would have hoped with high power running through it.They did start cold...that mostly explains the curve, the tapering at 80% is intentional and in the manual, you are not supposed to be FAST charging beyond 80%!
Do you think a recommendation suggesting that you do not DCFC over 80% too often will become Ford's position and they will hard limit a 100 KWh pack to only provide 70 KWh usable? Poor standard range. I think you are joking correct?They did start cold...that mostly explains the curve, the tapering at 80% is intentional and in the manual, you are not supposed to be FAST charging beyond 80%!
You can charge to 100% just fine, only the last 20% will be at 11kW max. On a roadtrip it's best practice to charge 10-80 then to the next charger. At home you can charge to 100% if you start your trip shortly after it's full...Do you think a recommendation suggesting that you do not DCFC over 80% too often will become Ford's position and they will hard limit a 100 KWh pack to only provide 70 KWh usable? Poor standard range. I think you are joking correct?
It has already deviated from historical understand and 94 KWh usable (my original assumption) went to 88 KWh usable. That has been advertised and is in peoples sales agreements. Guess we need to understand Fords definition of usable. Not suppose to (too often) and prevented from doing it are two different things with the latter again really not common historical understanding. You would think if that is where Ford is going to hang their hat than legally they should spit it out instead of putting out feelers. Bet that would not go over well in the real world (may be OK here). You should not red line a mustang so we installed a governor that limits rpm to only 70% ?.
There are plenty of places where the full 100% is needed to make the next fast charger, even for a ER RWD. The artificial limit to DCFC at 80% and immediate downgrade to AC speeds is really troublesome to me. It might be in the manual, but it wasn't mentioned a year prior when I reserved, and no other BEV does it that extremely, so I feel like we were justified in assuming Mach-E wouldn't either.They did start cold...that mostly explains the curve, the tapering at 80% is intentional and in the manual, you are not supposed to be FAST charging beyond 80%!
Again... it's another pre-production unit.Do you think a recommendation suggesting that you do not DCFC over 80% too often will become Ford's position and they will hard limit a 100 KWh pack to only provide 70 KWh usable? Poor standard range. I think you are joking correct?
Yep. Like so many things EV, DCFC charging times appear to be heavily affected by cold.Hmm, 20 percent to 80% in less than what Ford has promised for 10-80%. Obviously, there is more speed there with a better battery temp. At first glance, I can see that this is a classic cold-gating case. This is what you should expect /hope for in winter.
