Motor coolant over temperature
Mrs Chivus
Richmond, VA
2021 Ford Mustang Mach-E
I just got a message on my car "Engine coolant over temperature" and "Motor coolant over temperature". I just picked it up from the dealer 4 days ago after having the HVBJB recall done and the paperwork says "Had to perform coolant bleed/fill procedure multiple times due to failure at the end." I'm sure these 2 things are related. Any advice?
bshaw
Boston, MA
Don't drive unless you're going back to the dealer. If the dealer is a long ways away, then consider having it towed.
Tom L
Tom
Chippewa Falls, WI
2018 Honda Clarity
I had a similar experience with my 2022 Mach E and the problem occurred because the mechanic didn’t realize there were two coolant reservoirs in my 2022 that required vacuum filling. I’m not sure if the newest models still have two or only one.
Mrs Chivus
Mrs Chivus
Richmond, VA
Mine is 2021.
Tom L
Tom
Chippewa Falls, WI
2018 Honda Clarity
Mine is 2021.
Could be they neglected one reservoir or just filled them without the vacuum procedure, like they’re used to doing with ICE cars. This is part of the learning curve for service departments. The vacuum procedures takes about an hour instead of 5 minutes like they are used to.
Gimme_my_MME
Dearborn
This is almost certainly what it is. I would not do any spirited driving and limit all driving as much as possible until it gets corrected
Ford Motor Company
Official Ford Account
Hi there! I can look into your Mach-E's concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Mach-E's VIN?
Back to the dealer.
Geep
Paul
Saskatchewan
2022 Maverick XLT hybrid, 2018 Ford Escape Sport
And here in lies the problem, IF the service departments are not up to speed on training, shop tools and the will to think away from ICE then EVs will always suffer from these kind of problems. EV only dealer service departments such as Tesla know nothing other than EVs and therefore are better suited to get things right.
JamesStew71
James
Jordan Ford
mustang mach e
auto tech
some smoke for his tailpipe
zvez
chris
ga
I watched a pretty indepth video of the replacing main battery and the procedure for purging/filling the coolant. This guys vids are great
