Navigation inactive
lightnin
Tennessee
2025 MME RWD X batt, 2018 Subaru Outback
retired IT
2021 Mach-E 2wd ER, last update was 21B36; Power-up 3.6.1 was installed on 2022-11-16. There is no navigation icon on the bottom of the Sync (22228_PRODUCT Revision: 539) screen. If I ask the Ford Assistant to navigate to a destination, she says "Sorry, the navigation system is still loading. Please wait."
I think this started when I had to manually restart Sync (volume down and next buttons together) to be able to change from the guest profile to my saved profile.
Anybody else with this problem? Any ideas? (I did restart Sync again to see if that helped. No.)
StrWhtMME
Richard
Marietta, GA
F-150, Electric Focus. 21 MME Prm SR, 23 Maverick
Usually the soft reboot works, like you did. I had to do a hard restart by disconnecting the negative battery terminal for a different issue. It might be worth a try. Maybe the master reset on the Sync 4 screen. Good luck
lightnin
lightnin
Tennessee
retired IT
Didn't want incur drawbacks of master reset, so I waited for the next software upgrade. Sure enough, after Power-Up 3.6.2 on 2023-01-21, navigation is back.
MY21 J1 Premium RWD SR
In the future, you can also bring up the navigation app from the icon at the top center of the display. It shows the full list of available applications, including Navigation.
Once you get Power-Up 4.1.2, I think this icon might be moved the top left corner.
phil
LS400
Happened to me today. First time ever, after 20 months.
Waiting five minutes did not help. Turning off the car, and turning it on an hour later did not help. Rebooting the Sync screen, twice -- did not help.
What did work? I asked: "What's the weather forecast?" Car gave me the weather forecast, and was then immediately able to also do voice navigation. No more problem. Go figure.
Gimme_my_MME
Dearborn
Well done! You successful broke the loop
NY_Cade69
Cade
PA ON NY
Thanks to this thread! Mine did this yesterday, did the weather trick and voice navigation came back. :D
