Need to get passenger side window replaced
Womper
Will
Miami
2021 Mach E AWD Extended Range
My passenger side front window was smashed and I need to get it replaced. Safelite is giving me two options (see below) for the replacement. Which one will match the other windows from the factory? I have a 2021 Premium AWD extended range. Thank you!
Option 1: Solar, Passenger side, Front, Laminated, soundproofing, Data Sharing Etch
Option 2: Solar, Passenger side, Front, Data Sharing Etch
GadgetTech
Garrett
Des Moines, Iowa
2021 Ford Mach E Primium Shadow Black
You should see something like "sound screen" on the other windows which I would assume is the sound proofing they are referring too in option 1 and you should have that style. I have a Job 1 21 ME and all the glass is the sound screen type. I've heard there is a big difference so I would stick with it if possible.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
Don’t understand why there is a choice. Matching the intact window, option 1, is the only choice.
DevSecNetOps, General PITA
I think it’s safelite trying to trick the owner into a cheaper windows so Safelite makes more money
New2EV
Palm Bay Florida
Charger, Explorer, Chevelle, Mach E
The 2021 windows were laminated for additional sound proofing. At some point (2022?) Ford changed to cheaper standard glass as it didn't make much difference in noise. If you had laminated, you should stay with it. The window will have this on it:
Ford Mustang Mach-E Need to get passenger side window replaced IMG_20220416_121904
You should take the picture like above and tell Safelite to match it.
ElectricPony
Jay
MD
2015 Acura TLX
I'm in the same situation and need to replace the passenger side front window. If you don’t mind me asking, how was your experience with Safelite, and would you recommend them? Thanks!
