Dysan911
2023 Mustang Mach E GT
Technical Software Analyst
Have you taken a drive and then try it?
Actually not yet. It was "Downloading" while i was heading to work. When I parked and turned off it said Sync was updating and later when I checked the FordPass app it shows a succesful completed update so I thought the new feature might be avail right away but I"ll check it later after I get back home tonight.
Dysan911
That did it! Took a short trip nearby and now I’ve got the new climate settings.
dallowev
DFW
2023.5 Ford Mach-E Premium EXR
Didn’t work in the morning, then the update ECG-24.2.5.6.2 installed and it worked same day immediately after.
2023.5. iOS app.
NiceandSimpleMache
Will
DMV
Future 2023 Mustang Mach E Premium RWD
Network Engineer
I just got the 10.1.0 update and drove my vehicle after the update. I got the update on my app now. 2023 Mache.
first_EV_is_a_MME
SoCal
2022 MME AWD Extended
Has anyone had an issue with this new update where you set it to let's say 80, but then get in the car and turn it on and it shows 65 (or last setting) on the center screen? e.g.I can't tell if it's actually setting the temperature or not.
Phil_Gtown
Phil
Gatineau
2024 Mach-E Select AWD Standard Range
Hmmmm,
Could this be linked to trim level ? I have a Select. I have Ford pass 5.6.0 and my car’s software says it’s up to date. can't seem to remote start but I have a Fan icon that can “start or stop” climate. On the car menu/settings it’s either Automatic or same as last settings.
my point it, I don’t seem to have the fancy climate option of telling me what temperature I would like in my cab, heated seats or defroster…
Is this about a pending OTA software rollout?
thanks
grein002
Scott
Durham, NC
Just updated my 23.0 GTPE last night w/FDRS, applied around 8 updates. All is good, but this feature still not showing up for me, iOS 18.0.1, Fordpass 5.6.0
Tried again last night, and new settings are now showing up.
It is not based on a FordPasss update since it works on my Lightning but not Mach-E...
MacherAWD
North Shore MA
Healthcare Software
I just got climate settings in app for my 2021 Select. I am in EAP and Fordpass beta but have not gotten the 10.0 update
Edit: looks like it was just a notice when opening the app, doesn't appear to work yet.
Johnny572
Mach E GT performance
I’m on 6.14 still can’t see this new feature. I wonder why I’m stuck on 6.14. Ford your update roll out still needs work.
FYI you will need the latest HVAC update applied before the buttons will show up.
