OBCC Update in FDRS
chesteroberto
Rob
Bluffton, SC
2021 Ford Mustang Mach-E Premium
I've got a new OBCC update sitting in FDRS for my 2021 RWD Std MME. I can't recall if this is a quick update or if it requires a power supply.
Could someone please refresh my memory? Any idea what is changing with this update?
TIA!
kltye
IB MME Premium RWD
TIA!
When I've done it in the past, it seemed pretty quick and didn't need a power supply. I'd make sure the 12v is as charged as possible before starting the update.
chesteroberto
Rob
Bluffton, SC
Thanks for the quick response. I'll give it a go later today.
Mike G
N. AL, USA
Took 4 minutes yesterday using a VCM3 and I did use the powersupply. You might get away without using one, dunno. Just watch to see that it doesn't drop below 10.0V or you'll probably have to go get a PS and do it over.
chesteroberto
Rob
Bluffton, SC
Thanks, Mike. Maybe I'll just set up the power supply to be safe.
kltye
IB MME Premium RWD
Have you had a chance to test to see if there are any material differences compared to before the update?
Mike G
N. AL, USA
Normally, OBCC updates have been pushed out in the past for one of two reasons...either to make the car compatible with some new DC fast charger that has just come out....or to adjust the charge curve (tweak).
I don't know why this one showed up, but we haven't had an OBCC update in a good long while. And it may have been pushed out to correct some other issue that I don't know about.
gz3490
Manny
Valley Glen
Mach-E
Not sure if it's the same update however I just received an OBCC OTA update. Not much in the release notes, hopefully it's s tweak in the charging curve. Hoping for the best.
CarGuy11
Pittsburgh
2022 MachE4X Prem, 2020 GRSupra, 2016 Corvette Z51, 2024 Emira
What year is your car?
Hyperion
Cosmin
Boston
2024 Premium AWD SR
I got it yesterday too (24 Premium). Update OBCC-AS.AU. Release notes are vague:
"We’re updating your vehicle’s Plug & Charge functionality to keep everything running smoothly when connecting to a public DC fast charger "
