obd2 scanners
Twilloo
Terry
Young Harris Ga
2021 Mach e Select AWD comfort/tech pkg
Retired LEO
Just wondering what obd2 bluetooth scanners are mach e owners using that work well.
benk016
Tulsa, Oklahoma
2021 Mustang Mach-E GT
I'm currently using the VGate iCar Pro BLE. It works great, and is also compatible with ABRP live data feature. But It also works fine with Torque, and CarScanner, and is compatible with iOS Devices as well.
Twilloo
Terry
Young Harris Ga
Retired LEO
thanks as I was looking that that one also
Twilloo
Terry
Young Harris Ga
Retired LEO
Hello, I saw that you use the icar so I got one and cannot get it to connect. I plug it in my mme and see the 3 lights and then it goes to the one red light. I have an android s21 ultra and cannot get it going. any help would be greatly appreciated.
benk016
Tulsa, Oklahoma
You should actually see two BT names for it.
Ford Mustang Mach-E obd2 scanners Screenshot_20220120-182407_Settings
If you want to use it as a classic Bluetooth device, do a normal pairing with the Android-Vlink option.
If you want to use BLE, don't pair it, just open your app and choose it.
Once it connects the blue light will light up and flash as data is transferred.
If you're trying to use carscanner, you need to go to the apps settings and set it up.
You can choose BT or BLE.
BT: (Pair the device in your android bluetooth connections FIRST)
Ford Mustang Mach-E obd2 scanners Screenshot_20220120-181848
Ford Mustang Mach-E obd2 scanners Screenshot_20220120-181917
BLE: (No pairing required, Just search for it in the app)
Ford Mustang Mach-E obd2 scanners Screenshot_20220120-182429
Ford Mustang Mach-E obd2 scanners Screenshot_20220120-181936
Twilloo
Terry
Young Harris Ga
Retired LEO
BT:
BLE:
I really appreciate all the effort you put in this trying to show me. I think that I did do what you showed and all I got was just that red light and an error message from car scanner saying cannot connect. I will try again to make sure I did get every perimeter set right. Thanks so much again. Terry
benk016
Tulsa, Oklahoma
I did do a firmware update on the dongle before I used it. That may be required.
Their download files are here:
https://www.vgatemall.com/downloadcenter
The specific update for this model is at this link:
https://www.vgatemall.com/filedownload/68160
mattbostonmache
Matt
Newton, MA
Rav4
What info would an obd2 scanner provide applicable to an EV?
All sorts of stuff. High voltage battery SOC, KwH to empty. State of 12V battery. Temp of various components. Steering angle. Whether your brake light is on. Tire pressure.
Here are some examples from Car Scanner:
Ford Mustang Mach-E obd2 scanners C32C22CD-C92C-4A43-8E46-793B66E49704
Ford Mustang Mach-E obd2 scanners 7CB9AC8C-FEB6-4923-9DE0-D8C9E21EAA91
Ford Mustang Mach-E obd2 scanners 9B89C619-F67D-48A4-939C-6C96AC582705
Ford Mustang Mach-E obd2 scanners EB92A23E-6799-41D4-BE04-7E9AAE389801
Ford Mustang Mach-E obd2 scanners 50224244-4D67-4527-86AC-8A59964F73C0
Ford Mustang Mach-E obd2 scanners C65F677F-62AC-413D-85EE-B96883013A3D
Ford Mustang Mach-E obd2 scanners 623AF82C-7870-4184-B7E8-C9266DF0E0DA
Ford Mustang Mach-E obd2 scanners AA622CBB-75AF-40FC-AA73-4FF85B5B7509
mattbostonmache
Matt
Newton, MA
Rav4
can any of the OBD2 apps set vehicle config settings?
On my RAV4, I could use Carista (app and OBD2 reader) and set all sorts of things. But Carista doesn't support Fords.
benk016
Tulsa, Oklahoma
There are no phone apps that can make changes. There is a windows application called "Forscan" that can make configuration changes though. Another is UCDS, but it costs money.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
I have an Autel ML529 and I don’t think it does any if this. Please recommend an obd2 scanner I can research. Thanks
mattbostonmache
Matt
Newton, MA
Rav4
i bought the iCar Pro BLE after following another discussion on here (about the new feature in A Better Route Planner where it can get live status from your car).
Vgate iCar Pro Bluetooth 4.0 (BLE) OBD2 Fault Code Reader OBDII Code Scanner Car Check Engine Light for iOS/Android https://www.amazon.com/dp/B06XGB487...t_i_156AN782WDG9E4YCF6VA?_encoding=UTF8&psc=1
