One pedal changes?
1969Mach1Mike
CO
1969 Mach-1, 11 R56S MINI, 25 RIVIAN R1S Gen2 , 22 Mach-E IBSM Premium 4X.
Minister Of Awesomeness
It definitely changed on my '24 GT. I can feel it just leaving my neighborhood, which I have done now for 4 years in MMEs. I used to be able to roll up to the first red light and rarely touched the brake pedal. Not any more. I haven't gotten an update (that I know of) in quite a few months (I do track them, if I know about them).
Mine happened after the 12v update a few weeks back. Thats the only update I've seen in 7 ish months.
JeffGo
Washington, USA
2024 MME GT in Eruption Green
Are you referring to ECG-25.2.5.7.1?
I don't recall getting that one, but maybe it happened behind my back. I don't know if that applied to 24s or not. But the timing seems right.
EDIT: According to owner dot ford dot com,
It’s been more than 90 days since your vehicle was updated.
1969Mach1Mike
CO
Yes. That's the last one I've received and the first one in 7 months. Unless they just snuck one in without telling anyone, or showing an update.
I'm just glad i'm not the only one noticing.
ctenidae
Alex
Stamford, CT
Solver of problems
I'm not sure how you can tell if a software update affected, effected, detected, or rejected anything. I find the drive control system to be so variable and twitchy. Some days it takes extra pedal travel, other days traction control is all over the place. The suspension swings between flint and wet teabags. The car is moodier than my teenager...
GrisGris
Tampa
'21 Premium RR ER AWD
Check the Drive Mode. Often it switches on it's own, and you might be in Engage without realizing it. It used to pop up an error message, but they decided to hide the message and pretend it wasn't happening. It usually doesn't even change the IPC graphics anymore when it happens to me. What gives it away (other than the performance) is that my screen will show text in the Blue color that goes along with Engage, instead of the Orange that goes along with Unbridle. It usually "sticks" and requires I change it to Whisper, then Unbridle for it to actually change back.
You know, I noticed when starting up my car that the floor lights would flash orange and blue and ultimately stay blue. I thought it was just celebrating UF's national basketball championship with me, but perhaps not because I also noticed last week that my car was in Engage instead of Unbridled. So, there's another possible clue for anyone that something may be up with the drive mode.
honourx
Andrew
Mustang Mach E GT 2021
Marketing Manager
I have a 2021 GT and have also noticed the regen in Unbridled seems soft the past few weeks. Not sure if it’s related to the Blue Cruise 1.3 update.
RWD_ER
Cary, NC
'23 RWD ER
? definitely notice this after a few close calls with the breaking. I've used the braking mower in the past month or so than I have the entire time I've owned it, which is around 11 months. It's disappointing tbh, I was even thinking that the regen system was worn out or something
