Other factory door code locations
aporzio1
2022 Mach-e GT
I know the factory door code is on the Owners card (which I keep in the safe inside my house) but I just learned that on the F-150/F-250 the code is also on the back of the fuse box.
Anyone know if the code is hidden anywhere else on the Mach-E?
Edit: Nevermind, I just found it. There is a sticker on the fusebox in the passenger footwell that has the code printed on it. Gotta go get a sharpie I guess.
markboris
Sonora, CA
Correct. It is a 7 digit code located on a white sticker on the BCM. European cars use the full 7 digits but in the US we use a 5 digit code so just use the first 5 numbers.
Ford Mustang Mach-E Other factory door code locations 1702587224385
It's also retrievable with 2 fobs. Why are you so concerned about it? Do you think a mechanic is going to write it down?
2026 Velocity Blue GT/CS
Why?
RXDOC
Hoss
Johns Creek, GA
22 MME GTPE, 22 Buick Enclave , 23 Hyundai Ioniq 6
Clinical Pharmacist
First time I was exposed to Ford's entry Keypad was on my new 1989 Ford Taurus SHO! Back then, that was the second Fastest 4dr sedan in the USA. With 220HP, and 0-60 in 6.6 sec, only the BMW 750 w/ V12 was faster. Back then, Keypad was needed. Now, not so much!
