Door Code Factory Code?
annaprins
Anna
2021 Premium AWD Extended Range
Just wondering if anyone's had this happen to them...
I have been using my door code for months now with no issue, and then all the sudden it stops working. I tried to go into the settings and reset it (or at least see what's wrong) and it's telling me in order to set my door code I need the factory code?? I bought this car used, so of course the dealership didn't give me one of those in my packet... Did some update break this for me? Am I going to need to bring this to the dealership and have them find my code?
nvabill
Virginia Beach, Va.
F-150, '22 California Route 1
SSM 49691 - March 25, 2021 - 2021 Mustang Mach-E - Missing Keyless Entry Secure Code Card
Some 2021 Mustang Mach-E vehicles may be missing the keyless entry secure code card. To retrieve the keyless entry code from the body control module (BCM), connect the Ford Diagnostic and repair tool > confirm the VIN > go to toolbox > select BCM – Factory Keyless Entry Code > press Download to retrieve and display the factory keyless entry code > then press Run to get the code.
END SSM
nvabill
Virginia Beach, Va.
Unfortunately when I bought the car used I was only given one key :(
I would definitely check with the dealer, it is my understanding that you can get a second key fob from Ford at no charge. I could be wrong because you are second owner but you need to check with dealer anyway.
I'm pretty sure that program has expired.
Art
Art
244SnowyGv932nFordC
Mustang Mach E
Retiref
If you have 2 key fobs, you can use them to display the factory code on the IPC. If not, the code is printed on the BCM in the passenger foot well.
I spent my entire life on computers. I was advised that I spoke in code.
It would be helpful to know how you could display on X. and what is the BCM.
I did understand passenger foot well.
kdonnel
Metro Atlanta
2022 CA Route 1, 2020 Bolt EV
BCM is the Body Control Module.
IPC is the Instrument Panel Cluster
annaprins
Anna
THIS was what saved me. It's insane that dealers want to charge you to give it to you when it's literally printed on a part in the car! Thank you! Though I can imagine I had it a lot easier fitting myself in there to read that as someone who is pretty small than your average mechanic would, lol. I'd assume that's why they just use a tool or something.
Note that the code on the Body Control Module is longer than necessary for a US-spec car. You only need the first 5 digits. ??
