Phone calls fail and bluetooth keeps dropping
400 VOLT
HALLNET
Boca Raton FL
2022 GT PE
Real Estate
Same with my S22 and I have the 4.1.3 update...wrecked reliability of initial phone calls...have to hang up and redial. Also got in and started car today to a blank screen...a first. Did the wheel button reset and it worked fine.
Johnnyweekend
Los Angeles
Volvo
Yes. I have to make every call twice. The first call always has heavy static or no sound at all. Hang up and then dial again and it almost always goes smooth the second try. Started immediately after the most recent OTA and remains a problem. (Going on 4 days now....)
Same exact issue.
Ford Motor Company
Official Ford Account
Good morning! I'd like to look into your concerns. Feel free to send over a private message with your VIN and dealer info at your earliest convenience.
gokulmig
Gokul
2022 Mustang Mach E GT
I am having the same issue @Ford Motor Company , using Android auto wireless and then phone calls goes through but no sound, has to disconnect AA and connect only to Bluetooth to get it working. Which is pretty annoying
Ned
Ned
Prescott, AZ
waiting for ford
Hope this isn't the wrong place to put this. But - my 6 radio programs that come up when I select radio sometimes change from what I had programmed. It is usually the same wrong stations.
When I go to the place where my favorites are listed it is always correct. How can I get this glitch to stop.
agonmache
Arun
Fremont, CA
22 MachE select
In my 22 select trim, the phone call quality is terrible, especially on highways. Is there a fix for this?
Ford Motor Company
Hey there! If you send over a DM with your VIN and Ford dealer info, I can look into your concerns on my end.
superdave80
Santa Rosa, CA
2022 Mach E Select SR RWD
Is your profile switching to 'guest' or some other profile? That is a bug that has been around for a while. The way most people have stopped that is by adding an additonal 'dummy' profile. No idea why that works, but it seems to.
Ned
Ned
Prescott, AZ
waiting for ford
We don't have any profiles set. I try to figure out how to set profiles.
katydyd
Katie
Idaho
2023 Mustang Mach e
I have the same issue? Any fix?
MacherAWD
North Shore MA
Healthcare Software
I wasnt sure if it was my phone, Pixel 6a running beta 13 builds, but it seems like a wider spread issue. Most times when I make a bluetooth call (not using AA) the call fails, it acts like its calling but nothing happens, I then try again and it works fine. Sounds like what others are reporting.
Yes, same problem here. Been too busy to remove and re-add the car but I will try that to see if it helps. Mostly I get the cracking during the beinning of a call or and even during sound. Somehow they screwed up the bluetooth.
You don't have to make the call twice; you can put the call on handset and switch it back to the car from the car's phone screen and it stops.
Thank you for the tip! Will give that a try. :)
KevsMachE
Chicago
2023 Mach-e
Same issue for me. I have deleted and added my phone 3 times now and it makes no difference. It’s driving me crazy having to make a call, hang up and redial. Sometimes even that doesn’t work.
kkmoon
Vancouver, WA
2022 MME GT
I used to have this problem all the time. Sometime in the last 2-3 weeks, it started working correctly. I don't know exactly what changed. I think it was after the 4.1.x updates but not right after.
Ford Motor Company
Hey there. I can look into your Mach-E’s concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
