Phone gets very warm when using charging pad in Mach-E
schulmeia
Arnie
Mililani HI
Mustang mach e
Nuclear Engineer
When I use the charging pad in the Mach E my phone gets very warm. Do you have the same ecperience?
Up and Over
Massachusetts
2021 Mach E GT, Iconic Silver
Yes. My trips are 20-40 minutes so it is not too bad but the phone is definitely warm.
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
All wireless charging creates a ton of waste heat. Using CarPlay (Bluetooth and Wi-Fi) also generates heat. Both together can be A LOT of heat.
P. T. Magoo
Petersburg, MI
'15 Volt, '22 MME Ca Rt-1
Physical Therapist, Freelance Trombonist
Lots of great information in several threads here on the forum for mitigating this issue.
This thread may be of interest to you: https://www.macheforum.com/site/threads/my-phone-got-fried-by-charging-mat.10682/page-2#post-457337
I made a couple posts to that thread as I discovered things but the gist is: I find my phone which is in a thick, rubber-surfaced case does better when I remove the rubber mat/devider from the phone charging tray. I think the combined thickness of the case plus the mat kept the phone too far from the charging coils, and the non-skid properties of the phone case make the rubber mat unnecessary. Your experience may vary.
babgvant
Andrew
Mach-E GT PE
Software Developer
