Plug & Charge on FP app not working
RMoore
Rob
I activated my Blue Oval network last night and it shows up as active in my Ford account in Connected Services but I can’t toggle it to On in FP. I get the note below and when I click on the selector it just goes back to off. I’ve never charged on the road, only at home and work (free charging there) so today will be the first time I need to do that. I assume I’ll be ok but might have to initiate the charge via the app?
Ford Mustang Mach-E Plug & Charge on FP app not working A10AB22F-2494-401C-A0D9-FE719A0FA4A0
Worse case, you initiate in the app.
Make sure you have the latest version of the app. There are often server issues. Try deleting cache and then app, reboot phone, reinstall. If that doesn't work, try again on Monday.
Tampamike
Tampa, FL
‘24 Mach E Premium RWD
My experience with that was that it took a couple days to work. Seems too long but, I guess it is what it is. Like Rick said, if you really need to charge now, get the Electrify America app and use that to initiate the charge if Blue Oval won’t work.
DaveP
Washington state
2022 Mach E Premium eAWD iced white assistance pac
Real estate advisor
I have same issue. I toggle it on then to toggle off and get same message.
RMoore
Rob
Fortunately, this didn’t seem to affect my charging. I plugged into an EA station and everything just worked without my having to do anything.
RMoore
Rob
I may have jumped the gun when I said everything worked fine. It looks like EA charged my card about $6 after adding 32% charge (estimated to be 81 miles) even though I activated my Blue Oval network and my account shows free 250 kWh. Was there something I was supposed to have done for the charger to use those free kW instead of charging me $? Is it possible it takes a few days post activation in order for EA to know that I have a credit for those 250 kWh?
Edit: I’m a potato head—it turns out I didn’t look carefully at the charger and it shows that I received a discount equal to what they would have charged me without the free kW.
Mach-E Premium AWD / Ford Lightning
I cannot activate Plug & Share in FP app. It keeps “loading” forever.
Activated Blue Oval in my account in browser, but it’s not activating in the app.
Brand new car (that’s actually Lightning, I own Mach-E and Lightning), just received an email inviting to activate Blue Oval with free charge last week. Any ideas?
Ford Mustang Mach-E Plug & Charge on FP app not working C73E3C25-86B9-41BB-9834-6ABD2E2A4396
ChuckA
Chuck
North Branford, CT
Accountant-Retired
Have you gone through the Blue Oval function and manually select the charge station and manually authorize?
P&C never worked for me and this is how I used my free 250 kWh. When that was used up , I used the EA app since I had a discount plan that Blue Oval didn’t recognize.
RMoore
Rob
Update: just updated to latest FP (4.23.1) and it seems to have fixed the issue of Plug and Charge showing up in the app. Not sure if it’s coincidence: could it have just been that the system needed a few days to catch up since I only activated the charging network last Friday?
ThatGuyLando
Iowa
22 CR1
Software Developer
Plug and charge has worked for me a total of 1 time since I got the car. Every other time on different EA chargers I just get errors. Had to turn it off to be able to charge the car on public chargers.
