josephyancey
- Joseph
- Apr 25, 2022
- Arkansas
- 2021 Mach E CR1 (Job 1)
- Software Engineer
I've got a Job 1 2021 California Route 1. Over the past couple of months I've gotten the "Plugged in Not Charging" message quite a bit. It charges for a few minutes then just stops with this message in the app. This has happed at home and at a destination charger that I use once a week or so.
At home:
The car is set to charge to 90%. No charging time is set on the car or the charger. The charger is a Pulsar Wallbox on a 14-50 set to charge at 40A. When it happens the car says "Plugged in Not Charging" and the Pulsar Wallbox says "Paused - waiting for car to request charge" (or something similar). If this happens unplugging it and trying again usually fixes it. Sometimes I have to do this a few times but it eventually works. This happened often for a week or so then was perfect for a few weeks only to start again last night. I did notice last night that the charging speed seemed to toggle between 6.4kw and 8.6kw every 10ish minutes (per my wallbox).
At the destination charger:
No max charge percent or charging time is configured. There are 2 32A chargers (Edit - correction, they are 40A chargers). I'm pretty sure they are both on the same 80A circuit. Both seem to be able to charge a friends Lightning but error with my car. We tested this at the exact same time and his truck charged and my car wouldn't. Unplugging and trying again seems to not help it but I haven't tried it more than 2x in one go.
The fact that it happens at two different locations makes me think it's something with the car and not with the chargers. I've got an appointment with Ford next week to have the brake wiring recall dealt with and am going to have them take a look at it. I'm not optimistic that they are going to be able to reproduce it since it happens relatively rarely. I wish there was a way for the car to tell me WHY it decided not to charge.
At home:
