Possible to disable wireless CarPlay?
gordonf238
Gordon
NYC
Mach-E AWD, Ext. range
As of last week, we started having real issues with Apple CarPlay on our Mach-E, which has worked flawlessly over the past year. This morning I've had to reboot Sync in our Mach-E three times, and reboot her phone twice, then remove and re-pair them before CarPlay finally worked. It's gotten to be beyond frustrating.
Does anyone know if there's a way to disable wireless CarPlay and only used wired USB connection?
I've tried disabling wireless app projection, but when I attempt to re-pair and enable CarPlay in the Sync, it forces me to re-enable wireless app projection.
If anyone has any tips, I'd surely appreciate them guys!
Neil4Real
Why do you need to disable it? Just plug in the phone you want to use for wired CarPlay. That’ll take priority.
Polar
SBJ
PNW
2021 Select RWD SR
Settings > General > Car Play > “CarName”
Disable this option below - that disables wireless car play - currently I am wired CarPlay only.
Ford Mustang Mach-E Possible to disable wireless CarPlay? 885E410C-1E7D-4F49-8039-EFEC522EA703
gordonf238
Gordon
NYC
Polar, thank you! Let me try that. I really appreciate your help.
OrchidMania
Miami Beach
Grabber Blue Premium ER
Retired IT, School Math Volunteer
Wow I want opposite! Going to check out settings
gordonf238
Gordon
NYC
Thanks guys, this worked like a charm. I've disabled wireless app projection and simply click Enable in Sync when the prompt came-up upon connecting the USB cable.
Now it only connects via USB cable, and the connection is instant!
It also charges the phone unlike that magnetic charging pad that only works for a few seconds.
OrchidMania
Miami Beach
I went into settings. general. And I don’t see a CarPlay option?? With or without my phone in car. Any ideas? I want my wireless back
Polar
SBJ
PNW
2021 Select RWD SR
What version of iOS are you on? I’ve had that in the same location since at least 15.
Ford Mustang Mach-E Possible to disable wireless CarPlay? 1D4B9097-2E56-46F8-ACCF-983725A81C0B
OrchidMania
Miami Beach
Ohh on my phone ok. I can get there but no option for wired or wireless. I think am on iOS 16
Polar
SBJ
PNW
2021 Select RWD SR
Did you read - really read the toggle message - it’s there in my top image. The yellow circle cuts off the words a bit. Last part of the second paragraph.
But if that is on, then make sure wireless app projections is enabled on your MachE Sync settings. Those should be the only two options; Bluetooth is on on your phone (and wifi)?
dan_meh
Daniel
Alexandria, VA
Technical Writer
I’m a new owner and my wife was unhappy with the car because wireless Apple CarPlay was so bad. This forum is cheaper than couples therapy ?. Thank you!!!
