kennelh
Louise and Ken
Northern California
So how do you tell what drive mode the car is in when you start your trip with 6.8.0? The Mach E does not default to Engage so if I have been driving in Unbridled and my wife gets in, and I forgot to change it back it will be bad leaving the garage.
I believe the drive mode is associated with the profile linked to the fob or PaaK, so if you and her each have a profile it should be fine.
MachEInCO
Alex
Colorado
2022 MachE
Got 6.8.0 today but the release notes are very different from those that started this thread. Late 2022 GTPE. Same notes in-car as in FordPass app.
Ford Mustang Mach-E PowerUp 6.8.0 released IMG_5794
CarGuyBill
Georgia
2025 Mach e GT Performance Upgrade - 2025 Ford Bronco Badlands Hoss 3.0
Photographer
We both use the same key fob I do have two fobs but I gave up on the PAAK over a year ago after several phone calls to Ford and hours on the phone with it not working.
PedroDaGr8
WA, USA
2021 Mach E Premium (First Edition)
If you look VERY carefully there is a faint geometric pattern in the corners which is only there in Unbridled mode.
itzbilly
New York
2022 Star White Premium ER AWD
got the update today with same release notes
LUV_RED
SoCal
2022 MME ER RWD, 2023 Lexus RZ 450e
Same here. 2022 Premium RWD.
ZombieJester
Josh
Lake Forest, CA
2025 Shadow Black Mach-E Premium Extended/ Retired: 21 Mache-X Rapid Red
I am having a hell of a time getting this one installed. SOC was at 90 and I get the "interrupted by a process" on install attempt. Letting the car run to get my SOC up higher today to try it again. Have a 4 hour round trip drive tomorrow so that should also help.
See this: How To Get Failed OTAs To Install
Don't skip any steps for a particular method.
CarGuyBill
Georgia
Photographer
Perhaps ambient lighting changes per mode?
The only thing I see that changes is the text color on the main screen in the tray icons which is very hard to see. I called Ford and spoke with the Sync Team and opened a case. That is the only way things will change if we open a case.
YunniorO
Jacob
Westminster, Colorado
2021 Mach-E Premium AWD (Job 1)
Or send them like 5 voice recordings using the record feedback ?
Kidding, Ford engineering would probably hate you lol
