Problems "long-term" with Mach E
Guss-E 2021
Pierre
New Hampshire
2022 Mach-E Prem AWD ER
Compliance Specialist
Mine is 3.5 years old, and shows no signs of old age. Both electronic and mechanical stuff all works like new.
The same with my similarly aged 2022 Premium with exactly 55,600 on the odometer. I saw a headline about someone with 250K on their Mach-E (Electrek maybe?). I don't think I actually read it so I don't know what out of pocket costs they incurred.
Machspeedmach
Juan
United States
2021 Ford Mustang Mach E
Anything relating to the charge port is covered by the 8 year, 100K EV warranty, which should have included your #2. I just had my entire charge port replace and it was covered.
My 2021 Mach E just ran into the red ring charge port coupler fault cord system lock fault actuator assembly issue.... Happened at home with a level 2, but somehow affected it and didn't find out until trying to use a level 3. Im at 82k miles. How did you get the dealer to replace the charge port coupler under the electrical component warranty?
I didn’t do anything extraordinary. The car had a code for charge level being throttled due to charge port overtemp, so they replaced it - the charge port assembly, not the lock actuator.
Billyk24
William
PA
I am sad and depressed to say that we have had to have both the Front and the Rear Electric motor/drive train replaced on our 2024 Mach-e AWD w/Ext range battery. I am very disappointed. It started with a mechanical dissonance or hum that started when I was driving at an even speed, like with cruise control. There was a loud hum/vibration from the front and also the back motors.
They replaced the front electric motor and drive train (planetary gear), 3 weeks ago. The noise was still there emanating from the back motor. It's in the shop and they will be replacing the rear motor and drive train.
I'm really depressed about this. My technician says he has never seen this before. I live in the Kansas City area and take my MME to Olathe Ford, Olathe, Kansas.
First time I have read or heard of such. Glad it is covered by Ford.
