Random Noob Questions!
PhillyYa
PhillyYa
Philadelphia
2022 Mach-e Premium Extended
Phone is definitely linked. Locking with the key though may have done the trick.
PhillyYa
PhillyYa
Philadelphia
Check that, actually no. So IF I lock the car with the key fob, the seat will move into position when I get back in. If I DON’T lock it with the key (I.e. walk away lock) then the seat will NOT move back in position. The electronics in this car is driving me stark ravingly mad.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Retired Engineer
There is also a way to change the software with Forescan so the passenger mirror tilts in reverse. However, if you have the 360 camera view, you will likely find that you don't need the mirror tilted any longer since the 360 view shows you everything you need.
Don't think so, but with the 360 degree camera and the proximity sensors I'm not sure you need it.
I did the FORScan update and actually have found the mirror tilt to be very useful. I find that if parking in a spot where I either need to get as close the the curb as possible, or avoid an obstacle, having the mirror tilted can make a huge difference! I just wish there was a warning when you're about to curb your wheel when making a right hand turn!
Ford Mustang Mach-E Random Noob Questions! IMG_0210
PhillyYa
PhillyYa
Philadelphia
I agree. Mirror tilt has been standard on every car I’ve had over the last 10+ years. Silly not to have this feature activated. Anyone with Forscan in the Philadelphia area?
I have never had a car with it, and had Ford's since 1998.
Wouldn't help on right turn road rash either.
