Mach1E
- Sep 5, 2021
- Florida
- 69 Mach 1, 11 GT, 21 GTPE- sold, 24 Taycan 4S, 20 F type R
There is no free lunch though.I can't say much about how much the thinner air reduces drag. Probably the physics behind it is pretty trivial and one could calculate that. But I think it wouldn't be very much.
I think the much more important point here though is that there is generally no negative effect of altitude on EVs, which is not at all the case for ICE vehicles. Combustion engines do significantly loose efficiency with increasing altitude due to the lower air pressure and less oxygen.
Yes- thinner air equals less wind resistance.
However it also typically means colder temps.
Colder temps can kill range.
Ideal setting for max range- high altitude and hot temps (80+ degrees).
