Range drop leaving garage
05reinvent
Steven
Newbury Park, CA
Mach E
2023 ME ext range, in garage leaving in am range shows 165 start driving range drops to 155. Travel 8 miles to work range drops to 136. Any comments
Ford Mustang Mach-E Range drop leaving garage shrinkage
05reinvent
Steven
Newbury Park, CA
Mach E
Not so cold in SOCAL 50F but ok but why does range drop 16 miles for 8 mile trip?
Snakebitten
Coastal Texas
2023.5 Mach-E
In Socal, isn't 50F basically freezing? ?
Seriously, ambient temperature has that kind of impact on the algorithm. Can be very influential.
05reinvent
Steven
Newbury Park, CA
Mach E
As I continue to drive during day, I notice range becomes consistent with distance traveled but not sure range is ok or is it "braking recharge" that brings range into normal.
Battery likes 77 degrees. At 50, you will get lower range. As you start driving, it adjusts the range based on current conditions. Range is fine. All braking, or removing your foot from the accelerator, results in recharging, which has nothing to do with your range changing.
2FlyMache
Patrick
Martinez GA
2021 Rapid Red Ex4 MachE
If you are relying on the guess o meter then it will be misleading especially if you don’t have a lot of drive time then it hasn’t learned your driving style yet. I have had my car for 3.5 years and range is relatively close but i still mostly rely on battery % consumption over miles driven to project out. For example, if i go 25 miles and use 10% then roughly 250 miles for 100% start
05reinvent
Steven
Newbury Park, CA
Mach E
Makes sense
Deleted member 19354
Guest
Will be interesting this winter to see if EVowners learn any lessons from last year bitter cold (Chicago)
They won't. Those were largely people without home chargers, driving for a service, who waited too long. Chicago has a lot of old Tesla Superchargers also.
