Range estimate immediately after resetting
MarkWill
US
Mach-E Premium
I posted a similar question in a Facebook group but I was overwhelmed with responses educating me about range (how I drive, temperatures, it's just an estimate, etc). My question is NOT about range specifically - it's about the impact of a reset on the range estimate.
So let me narrow this down to a very specific question.
If I have an Extended Range AWD Mach-E and I reset my trip history (i.e. there is no driving history) and I have an 80% charge what would you expect the range estimate to be?
To reiterate, this is not a question about how to increase range, how the number presented is just a guess or any of that. I am asking about how the car would determine the figure to display IMMEDIATELY after a reset ( therefore with no history) and with the car not having yet been driven a mile, since the reset.
ack154
2023 Mach-E GT PE
If you reset everything, I'd expect an 80% charge to be whatever 80% of the 100% charge says. And I'd also expect the 100% charge to be really close to whatever the EPA estimate is for your config. But that doesn't mean any of that is exact or consistent.
Teslaeata
Nottingham, England, UK
I reset mine only a few time as I found it a pointless exercise because it soon reverts to real-world range according to ambient temp my driving style and all I’m sure you’ve already been inundated with.
Following a reset I found it to read around 379, one time below and another 384 at 100% charge as I seem to remember.
Mine is ER RWD June ā€˜21 Premium with stated range of ā€œup to 379 milesā€.
Does that help?
80% of EPA estimate, adjusted for current temperatures.
MarkWill
US
Mach-E Premium
Agreed. In the absence of any driving history, I'd expect to see 80% of 290 (Extended, AWD) = around 232.
But I am seeing much lower (around 195 after a reset). I don't really understand how it comes up with that. This is in a garage with outside temperatures in the mid-50s, so pretty mild.
But I am seeing much lower (around 195 afrer a reset). I don't really understand how it comes up with that.
W-E-A-T-H-E-R.
Ford Mustang Mach-E Range estimate immediately after resetting shrinkage
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
There are two things you can reset.
The trip does nothing for range estimation. But this one helps.
Ford Mustang Mach-E Range estimate immediately after resetting IMG_0004
MarkWill
US
Mach-E Premium
Yes, that's what I have reset (to clear the full driving history).
MarkWill
US
Mach-E Premium
W-E-A-T-H-E-R.
Everyone suggests the weather thing...but immediately reducing the estimate by 100 miles on a reset (as compared to the EPA figure for this car), with the car in a garage with outside temperatures in the upper to mid 50s? That doesn't seem like the explanation to me :)
MarkWill
US
Mach-E Premium
To clarify why I am asking...
This part of an investigation I am doing about the range we are seeing on our car. Obviously it's meaningless to ask "What range should I be getting", since there are so many variables. But, given what I know (driving habits, terrain, temperatures, etc) our 2024 Mach-E Premium Extended AWD seem to get pretty poor range.
To help research this, I decided to at least temporarily remove driving history as a factor. So, as a one-off, I thought I'd reset and then track carefully from there.
I had expected that, without any driving history, the car would show a range at least roughly in line with EPA numbers. For me that would mean around 290 * 80% = 232, or thereabouts, since it has no other data available.
But,, to my surprise, I see a number of 193 miles and I can't understand why or how it would reach that figure. This after I reset, the car is in the garage and has not been driven.
Now, all that said. while I think this is REALLY unlikely, someone suggested I check I actually DO have an extended battery. All the documentation and the VIN suggests I do.
But if you take the STANDARD range AWD and do the same math....you get very close to 193 :)
Jgg181
JG
Davenport, Florida
2023 Mustang Mach E Premium Extended Range
Simple to test for that..
if when you charge from 20% or less, if the ā€˜full’ charge is less than 70 kwhs, you have pretty much solved the mystery.
Teslaeata
I never get more than 270 miles in summer and around 240 winter for an ER RWD Premiun that ā€œcouldā€ return 379 miles. Right from day 1. Not that much different now.
Did you run a check on your HVB SoH? That’s usually a better yardstick of how your battery’s doing, eliminates all the imponderables affecting range.
And then a cell by cell Voltage & kWh health check?
My SoH is 94% at 40mths just under 100k miles and difference between each cell’s Voltage & kWh rating is five eights of nothing so still a pretty healthy battery pack.
There is a STRONG temperature influence in the calculation which you underestimate.
There is more biasing at lower SoC than at 100% in the latest software.
If you are trying to determine the battery health, you need to use a scan tool to read the SoH parameter, you can’t use the range figure.
MarkWill
US
Mach-E Premium
Can you clarify what you mean by my under-estimation? At this point i am just trying to understand if I have a problem here, so certainly open to all ideas. But, immediately after a reset, is the suggestion that temperature alone could explain why the range displayed might be 40 or miles less than "optimal"?
The outside temperatures were in the mid-50's at the time and, in the well-insulated garage, I would imagine the temperatures around the car was upwards of 60. Perhaps I am misunderstanding, but that doesn't seem like the sort of temperature that would result in such a significant drop in that initial estimate, no? I was expecting (significant) range drops to become evident only at lower temperatures than that.
But, for now, I remain surprised at the 193 figure (even if 60 degrees might have some impact on that estimate), so I am just trying to broaden my understanding before digging deeper.
As to the scan tool, yes I am looking into that (I have two new EVs so need to understand if there are any implications for the device and/or the software I might consider, to get the most bang for my buck :)).
To date - and, respectfully, even allowing for your qualifier about temperatures - it is not clear why I am seeing a range of 193 miles after a reset, at a "comfortable" temperature and for an extended battery.
Thank you again.
There is no problem. Warm up the battery pack to 75ĀŗF, charge it to 100%, then reset the range figure. You'll be happier. Ford made the GOM to show essentially full EPA range at 100% to satisfy your type. The displayed state of charge is not the actual state of charge, so when it displays 80% you could be some amount less than that which varies depending on the hysteresis algorithm.
Yes, you are misunderstanding. If the ambient temperature is less than about 68ĀŗF, there is a huge drop the range figure as a result of the lowered temperature. That's just how Ford's calculation works. The actual drop in range is not that bad. It is conservative.
