Range: Tesla Model Y Long Range vs Mach-E
PappuMal
Pappu
Mustang Mache
Currently driving a 2021 Tesla Model YLR, and one great thing about Tesla is the 3rd party apps that you can connect to your Tesla account and record real world driving & charging stats. Teslafi and Tezlab are two I'm going to miss when my Mach-e comes in.
That said, one huge data point people look at when buying an EV is range, and Elon will tell the world his Model Y gets 330 miles range. This is completely true... if driving downhill on a 75 degree day. Real world, not so much. In the 15 months I've had the Model Y I've put 28k miles on it. The average across those 28k miles, ranging in temps from 19-95 degrees F ends up at 3.7 miles per kW. With a 75 kWh battery, that's a 278 mile range. Yeah, not exactly 330 like Elon wants people to believe.
Cool part, is I can pull data based on temperature. When I do, it's clear to see Tesla is overstating their range:
30 degrees - 2.9 miles / kW (217 mile range)
50 degrees - 3.2 miles / kW (240 mile range)
70 degrees - 3.8 miles / kW (285 mile range)
90 degrees - 3.6 miles / kW (270 mile range)
Keep in mind, these are all AVERAGES of a mix of highway/city driving of which I'd estimate are a 60/40 split between the two. I live in Northeast PA near Philly, so I do get a range of temps.
I bought the Model Y because of that 330 range, even though I liked the looks of the Mach-e far better because when transitioning from an ICE vehicle to EV range is king. Had I had this kind of info when shopping for an EV I probably would've gone with the Mach-e. Now, with knowledge and experience in owning an EV under my belt, I have the car I wanted from the start on order.
Hopefully this information helps someone else who might be in the position I was in 2 years ago.
I have both MME (mine; Route 1 RWD; 19 inch wheels; 10 month old) and MYLR (wife's; AWD; 19 inch wheel; 2 week old).
Have driven MME for 13k miles in CA weather and mostly flat driving. Usually get around 3.7 miles/kWh . That's 336 miles range on 91 kWh battery, higher than 314 miles range that we were promised.
So far MYLR in local drive of 118 miles gave 3.2 miles/kWh. Mind you, this is in summer of Bay Area. All the talk about MYLR being more efficient is pure BS!
voxel
Nelson
Altamonte Springs, FL
22 Mach-E 4X, 23 GC Limited
Your Y numbers are way off unless you are driving 85mph. I had incorrect efficiency numbers on the first two days (100 miles) of ownership that was in the 325 Wh/mile range but normalized to sub 280 Wh/mile after.
Normal Y efficiency is around 3.6-3.8 mi/kWh. Give it time.
Anyhow… I’ve owned 4 Mach-Es and 4 Model Ys over the last two years so I’m very familiar with both lol. Get TeslaFi to track your efficiency.
Ghost Ryder
LA
Tesla MYP, 22 GTPE
118 miles is a really small sample To make any conclusion about efficiency.
I have a MYP and a GTPE. both with 20k miles. Over their lifetime, the GTPE gets 2.6 mi/kWh. The MYP gets 3.8. Same roads. Same conditions.
PappuMal
Pappu
Mustang Mache
Sure. It is small sample and it seems with more driving average efficiency number are getting better. But I doubt MY will be more efficient than MME. Or that it will live upto it's promised range like MME. Will update in a month or so :)
AZBill
I have the CA Route 1 RWD and easily get 300 miles of range at 70-75mph freeway driving. I am in AZ and never drive in cold weather. In 30k miles the average efficiency is showing 3.7 mile/kwh.
awp0
Aaron
boston, ma
MME Premium AWD ER
Surprised this thread made it so far without a link to the Consumer Reports range test that compares a MME Premium AWD ER head-to-head with a Model Y LR in three different temperature ranges. Spoiler alert: total range is almost identical between the two cars at all three temps. Model Y is more efficient so it gets better cost-per-mile, but it significantly under-delivers against it's stated EPA range. MME's best real-world range is almost identical to it's EPA range.
https://www.macheforum.com/site/threads/cr-report-on-ev-range-tests.20961/post-494312
voxel
Nelson
They have the exact same real world range. The Model Y does it with a 18 kWh smaller battery (in reality 14-16 kWh usable difference).
Aerodynamic shape matters the most. Neither the Y nor the MME are as efficient as my former BMW i4 (sedan) which only had a 83 kWh gross battery and could easily travel 300+ miles at 70-75mph.
PappuMal
Pappu
Mustang Mache
Ok, we will see about the efficiency after a month of me driving MYLR.
For 330 miles promised range, shouldn't I be getting > 4 miles/kWh?
As a consumer, I care more about honesty.
So I paid Tesla for 330 miles range but get 275 miles?
But Ford over delivered on their promise so I get more value for the money I paid?
Had Tesla been more honest about real world EPA range, we wouldn't be having this conversation.
awp0
Aaron
boston, ma
MME Premium AWD ER
All I’m saying is that the Model Y even at only 275 miles of range is more efficient compared to the MME at 275 miles of range.
There’s been a lot written about Tesla’s EPA range. As I understand it, they chose a different set of EPA tests, which are apparently still valid but result in a very optimistic number. Seems crazy but whatever.
MacherAWD
North Shore MA
Healthcare Software
I am more efficient moving through the air than a Tesla, many things are more efficient. I agree with the other poster, Tesla owners are tricked into thinking they have more range.
awp0
Aaron
boston, ma
MME Premium AWD ER
Yeah, fair enough. Just like MME owners are tricked into thinking Bluecruise is a feature they own which doesn’t cost $800 year. All of these companies get away with whatever they can, and it’s on us as consumers to do the research. It’s not exactly a secret that Tesla’s stated range is exaggerated. Are people really forking over $50k and entering the EV world without any research?
MacherAWD
North Shore MA
Healthcare Software
Yes many people don't do enough research and companies are trying to screw people over to make more money.
PappuMal
Pappu
Mustang Mache
You maybe right about MYLR being more efficient than an equivalent MME
I give you that my comparison wasn't apples-to-apples, but so are not EPA tests!
I would have been totally fine were we told that MYLR's range is 275 miles. Yes, I did get an AWD but I don't really need that given > 95% of my driving is on nicely paved roads.
Range is the biggest factor I care about. So far, I am extremely happy with MME!
PappuMal
Pappu
Mustang Mache
I did fork over $50k on MME and got more than promised. MY now with so much discount and so many in my neighborhood buying it left and right, did blind me a little! Not complaining too much (just a little!) that Tesla wasnt totally honest.
voxel
Nelson
275 is highway miles. It's 300+ city miles.
If you love range, stay away from the GT PE trim. I had one... worst efficiency (2.5 mi/kWh) of all of the EVs I've owned and also tracked it twice and it was 6200lbs of sled.
I ask... why a crossover EV if you want range? EV sedans smoke crossovers in efficiency + range.
