Rear trunk opened on its own
dadofahusky
CT
2021 Mach E Premium
Twice now, my ‘21 MME premium opened its trunk on its own, no buttons pressed. Both times happened when it was parked in my garage and I walked into the garage. I do have PAAK enabled. Both times it hit the closed garage door (minor scratches). Has anyone else experienced this?
Engelbert
Engelbert
Philadelphia
2021 Mustang Mach E Premium XR AWD
Yes, twice in my '21 Premium Extended Range AWD. I don't have PAAK enabled.
For me, the trunk and frunk opened simultaneously and immediately upon turning off the car and exiting the vehicle. I didn't press any buttons (aside from the power switch), touch the screen, or even have my feet on the pedals at that point. Just turned off the car and lifted the interior driver door handle.
There are multiple accounts of this sort of thing across various threads. The issue seems to be so occasional that it doesn't get much attention. My rudimentary hypothesis is some sort of electrical blip upon vehicle shutdown that temporarily shorts the lead to the frunk and trunk simultaneously, triggering their opening. But I don't know how much sense that makes vs. other potential explanations.
cswebster
Northern NJ
2025 Shadow Black GT MME
Enjoying Life
Yes, at least once in a parking lot as I was approaching the vehicle. Haven’t seen that in a while though ‘21 AWD MME Premium.
Blue highway
Mach E Premium SR RWD
yes - rarely (every few months). It seems to only happen in my garage and since it doesn't hit anything I have not been concerned.
heisnuts
Darrel
Model 3 Performance
When you walked into the garage and the door opened, did you have the key fob in your pocket? I have found with our Subaru if I have the key fob in my pocket and am working in the garage the buttons on the key fob will get pressed in my pocket as i am moving around and the car will chirp/lock/unlock as I move. As soon as I remove the key from my pocket the problem stops.
If you do not use the buttons on the fob that much, you might try a hard fob case that would help prevent accidental button pressing when in a pocket/purse.
ReverendPete
Pete
Denver, CO
2023 MME Premium, 2018 Toyota Highlander Hybrid
Software Developer
If you have the kick-to-open feature, it might be something related to that. I have read a few posts over the years about people suspecting that a cat or some other critter had triggered the kick to open when the fob was in range.
dadofahusky
CT
2021 Mach E Premium
I don’t carry the fob with me
dadofahusky
CT
2021 Mach E Premium
Maybe a mouse? :)
spicy_taco
Jack
2023 Mach-E Premium AWD
I had it happen once on my 23 a few months into ownership. Pulled into work parking spot, put in park and turned off the car. Both car and frunk popped open.
shelnian
Ian
Seattle
2022 MME Premium AWD, 2023 Lightning XLT SR 312A
I turned on the kick-to-open feature in FORScan. I noticed that when it is hot out (80+ degrees) and the sun is on the rear end, it will occasionally open when I walk up towards the back (up to 30 feet away). I don't carry the fob so it has to be activated during my iPhone bluetooth connection. It hasn't been a problem for me.
Almondtree
Phyllis
Mach E
Yes and mine caused major damage when it opened when it hit my garage door.
dadofahusky
CT
2021 Mach E Premium
So enough of us has had this issue. Has Ford ever addressed it in a TSB?
spicy_taco
Jack
I don't think there is any particular fix for it other than turning off the feature which I don't want to do.
It also happens to cars without kick to open (like my 2023).
WallyS56
Keith
Washington
2024 Mach E Premium, 1969 Mercury Cougar, 1971 Ford Ranchero, 1993, F150 XL 4x4
Teacher
Happened once on my ‘24 with the rear hatch at the BucEs near Loveland, CO while charging at a Supercharger. I use PAAK and walk-away auto locking, but always visually check. Came back to the car (in a pouring rain) and the hatch was open.
