Reset door code
Hapsdoggen
Mads Holm
Dennark
Ford Mustang E-Mach RWD 98KW
Car Body repair
Hi
Any guide or is it possible to reset the door panel code...?
connoisseurr
Connor
Northern VA
22 Rivian R1T, 23 Tesla MYP
IT Engineering
Hi
Yes. You’ll need your factory code that came with your car. Changing the code can be done in the settings menu.
Hapsdoggen
Mads Holm
Dennark
Car Body repair
Cool thank you is it straight forward to do that....?
connoisseurr
Connor
Northern VA
IT Engineering
You cannot change the factory code.
You can set your own code, and change it.
Hapsdoggen
Mads Holm
Dennark
Car Body repair
I made my own code but cant remember it so i have to reset it...
You can erase the master code by entering the master code on the door pad, then press 1-2 within 5 seconds, then press and hold 1-2 for two seconds (within 5 seconds of the previous press). This will erase all personal codes and retain the master code.
