Setup charing maximum level
Inhyeok
MME
Hello, I did setup maximum charging level 85% but it keeps charging until 100%. I set up the charging time 8pm to 3pm. It looks like my setting is changig ramdomly "Use preferred charge setting " to "Charge when it plugged in" Does someone had an issue like this and know how to fix it?
Ford Mustang Mach-E Setup charing maximum level Screenshot_20220619-223744_FordPass
Are you using 120v?
ChuckA
Chuck
North Branford, CT
ā€˜21 MME Premium AWD ER in Infinite Blue
Accountant-Retired
Never heard of the setting randomly switching from ā€œuse preferred charge settingsā€ to ā€œcharge when plugged inā€ .
1 -Use ā€œuse preferred charge settingsā€ - 85% is okay.
2 -Set the charging time to what you want- 8pm to 3pm is okay. FYI- 8pm to 8pm = Anytime
3 - remember to set both weekdays and weekends.
AKgrampy
Fairbanks, Alaska
To be sure are you charging at ā€œHomeā€ and is your GPS recognizing that your car is at ā€œHomeā€ while charging?
Inhyeok
MME
thanks for guys I found the issue. I am using the "optiwatt" apps and it makes keep charging. I canceled the control from the app, it is fixed. thanks
