- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
If it's that bad, 23B50 isn't going to fix it. The software will only fix the situation where your car will charge for several hours and then stop because of overheating. If it only charges a couple minutes or not at all, then you have other issues that are going to require hardware replacement (new charge port or charger module). I would talk to your BEV case manager about this so the issue can get properly diagnosed.They did the update now my vehicle won’t charge. If I can’t charge then I can’t drive it.
FYI it's the SOBDM, not BECM. The charge port thermistor transfer function is part of the SOBDM software only.Strange that it won’t charge. All 23B50 states is that the BECM needs to be updated (new transfer function for overheat protection).
Hmm...good question.why only vehicles updated from 4/26 will have to have the new software? My Mach E was updated in the week of 4/8 and I had the problem with 1PD.
The version numbers are all different for each model year, battery, drive type, etc, so it would be an extremely difficult chore to assemble all those part numbers. The easiest way is to say if you have the 1PD issue, then you need the software updated in FDRS. If you don't have the 1PD issue, then don't worry about it.so.... are there specific version numbers of specific modules that need to be re-flashed (via dealer, FDRS, or OTA) such that it is possible to tell if you are 'done' and fixed ?
