Shall we make this Charging Port Protector?
Would you interested in getting one if we make it?
  • Yes
  • Probably
  • No
Results are only viewable after voting.
I see no value in it. The ONLY reason to have any protection there, during charging, is if you're in an environment that gets a ton of snow, or freezing rain. In that case, you'd want a hood that covers everything and is secured to the car. Because the fender isn't steel, magnets don't work. Ford makes a similar item to what you show, in Europe, but it doesn't provide CCS access. https://www.ford-accessories.ie/ele...ttachments/charging-port-winter-cover/2630165
AOSK
AOSK
Diamond Sponsor
Zac
california
Mach-E select
yes, we designed this according to Ford one.
we been thinking for quite some while now about making a snow protector,but can't figure out a universal fit solution, and we started to think probably a solution like Ford is the best solution at this point
that_macheguy
BRAYDEN
NORTH DAKOTA
2024 MUSTANG MACH E GT PERFORMANCE
I don’t see any need for this or the ford one. I live in ND and it is very cold and we get tons of snow in the winter. I’ve never once had a problem while charging.
MellowJohnny
Christian
YYZ
Solution Architect
I'm in if you remove the hole for the door latch port. You'll never need to close the door while charging (obviously) and it can get contaminated with ice & snow, preventing the charge port door from closing.
Make that one change and I'm definitely in.
Ford Mustang Mach-E Shall we make this Charging Port Protector? IMG_5548.JPG
I used this all year and the only winter charging problems I've had have either been from freezing rain or wet snow which melted and subsequently froze, completely freezing the charging handle latch.
rkmoray
Rick
Vaughan Ontario Canada
2023 MME
Software Development Manager
I am not an engineer(at least not mechanical, I am a software engineer) but what about your original idea shown, with a small door that opens up hinged at the top to protect from the top?
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
I will but this whatever the final version is. My car spends a lot of time parked outside at work. The snow builds on the charging handle and tends to get down around the port. This then makes it hard to close the charging door the next morning. This should solve that problem at least.
Something the covered the charging handle as well would be even better.
tfitzgex
tom
Portland Oregon
2021 Mustang Mach-E Premium extended range AWD
We designed this, but not sure if it's needed and if it's going to cover the mold cost.
Shall we make one? will you get one if it's 24.99$? any design opinions?
Only if you can add a "karen lock"
AOSK
AOSK
Diamond Sponsor
Zac
california
Mach-E select
Not to highjack your thread---but how about making some lift pads--I bet you would sell a ton of those. Just sayin'
jack puck? we are already making them. it will be pack of 4. We actually already made a mold before, but it is slightly too big to fit in the front hole, and we are now making another molding for it. we are just doing some testing now at this point.
we will also make some stickers, and include instruction in the package about the jack area so people from tire store or some situations like that wont mess it up
@macheconnection been helping us on doing some testing with it.
AOSK
AOSK
Diamond Sponsor
Zac
california
Mach-E select
we are thinking to cover that on our later design too, and add some slope on top of the charging area so that the snow could slide away
AOSK, please take a look at this so you fully understand the problem:
https://www.bmwblog.com/2016/02/21/bmw-i3-life-hack-charge-port-snow-cover/
You need to think more in 3 dimensions rather than just having a flat plate. It needs to protect the latch button of the J1772, otherwise ice will get inside and you won't be able to press down the button to release it:
Ford Mustang Mach-E Shall we make this Charging Port Protector? 11683292648_.pic
A bag over the whole thing is the best solution:
Ford Mustang Mach-E Shall we make this Charging Port Protector? 71+kZtCqUTL
CMRD
Canada
Mach E Premium ER RWD
I think a cover that keeps out snow and ice is a necessity. If it did that I would buy one
