Softer Suspension?
DeusEx
New York
2023.5 Mach-E Premium ER AWD
Did the springs go up in price? lowest I can find them is $80 each + ship.
The Rally springs are definitely more expensive than when giwu42 first started his post but cheaper than when the rear B springs were first released.
The prices for the springs seem relatively stable at its current level. The sway bars can be up $100+ cheaper depending on when you purchase, if that's what you are looking for, too.
IgorKl
Pacifica, ca
'22 MME CaliRoute 1 AWD and '25 MME Premium RWD Ext
here is from my records
Bob Howard PDC on 06/17/2025
Part NumberPart NamePriceQuantityTotal
RK9Z-5310-ASpring Front$80.132$160.26
Subtotal: $160.26​
Estimated Shipping to 94044 via Standard Shipping: $20.64​
Total: $180.90​
jksu
LA
GT PE Shadow Black Night Pony
from my recent tasca order:
RK9Z-5310-ASpring Front$86.762$173.52
RK9Z-5560-BSpring Rear$89.162$178.32
Subtotal: $351.84​
DeusEx
New York
Subtotal: $351.84​
That matches what my subtotal was in Nov. My final total was $427.18 after all was said and done.
Subtotal $351.84
Shipping (Standard)$41.42
Handling $8.80
Tax $33.92
Total $427.18
jksu
LA
Subtotal $351.84
Handling $8.80
Tax $33.92
Total $427.18
my total was $464 after shipping and tax... i'm hoping around $500 for the install for a $1000 total for the change. looking forward to the comfy ride, while still maintaining flat cornering with the magneride and eibach bars. should be arriving early next week.
Looking forward to your review. 😊
jksu
LA
good news and bad news.
bad news first:
i was sent 2 sets of rear springs. tasca had both 1) a larger blue ford heading label 5310-A (front spring) and 2) small tag with qr code and 5560-ABC (rear spring) attached to the springs.
i honestly didn't even notice the smaller tags since on cursory check of the larger blue ford labels, it looked like i was shipped two 5310-A and two 5560-ABC springs. what a pain and waste of time to have to deal with a return and potentially another trip back to the shop.
good news:
despite not having the correct fronts, the shop did install the rear springs and boy has the ride quality improved significantly! to use an overused phrase, it should have come from the factory this way!
i've always thought the mach-e had a stiff-legged ride. magneride improved/resolved the rear "bouncy" nature that existed to small degree on my premium RWD, but it still rode very stiff legged especially over small-medium bumps, especially noticeable at slow-medium speeds. in fact, i always felt magneride was best at faster speeds when the amount of travel was less critical.
not sure if ford did this purposefully for aero/battery-saving reasons... or just mis-judged how much the weight of the battery/car would use up minimal spring heights. either way, the car actually rides like a car now, rather than a truck.
driving back from shop on the pot-holed streets of LA, it's remarkable how 1" of additional rear travel alone really lets the shocks do their thing to absorb the small to mid size bumps. the eibach sway bars still keeps cornering flat.
debating even bothering with the fronts. you can tell the rear tire gap is slightly greater than the front if you look carefully. but since there's already a decent gap in the front it's not as noticeable as with a partially lowered car.
for now i'm waiting to hear back from tasca about about getting these extra rear springs returned and refunded.
if i do decide to order the front springs again, should i just do what i did last time and put in the part# again and hope they get it right this time?
or is it better to select by model and choose "2025 - ford - mach e- rally" and go into the rally parts catalog and pick out the front springs that way? is that safer?
Ford Mustang Mach-E Softer Suspension? IMG_3504
DeusEx
New York
Wow, that stinks. I ordered my springs from Tasca without issues, and I am surprised of the mix up.
What springs are you running in the front currently?
I think you could provide great feedback running your current setup and then switching to the front rally springs when you get them, if your financial situation allows it. I'm not sure anyone else has such a unique situation as yours where half the springs are installed.
bad news first:
good news:
i've always thought the mach-e had a stiff-legged ride. magneride improved/resolved the rear "bouncy" nature that existed to small degree on my premium RWD, but it still rode very stiff legged especially over small-medium bumps, especially noticeable at slow-medium speeds. in fact, i always belt magneride was best at faster speeds when the amount of travel was less critical.
debating even bothering with the fronts. you can tell the rear tire gap is slightly greater than the front if you look carefully. but since there's already a decent gap in the front it's not as noticeable as if this was a partially lowered car.
Definitely put in the part number and never enter in your cars info especially the VIN. I order these springs from them all the time and never have had an issue but I know others that have added their car’s info and have had issues.
I would absolutely have the fronts installed. It will ride even better and level out the car more.
jksu
LA
front are the stock GT PE springs.
i probably will eventually get the fronts done... it seems unfinished not to do the fronts too. and will be happy to report here any noticeable differences. but i can imagine it'll soften it more to take the sting out of things like speed bumps.
Yes going from 228 spring rate to 183 is a fairly decent change. You will notice a difference but won’t be as great as the rear.
jksu, you are the third person I know of on this forum to install Rally springs on a GTPE (Magneride). However, I don't think you installed the Eibach sway bars, did you? After you get the front springs installed and you live with it awhile, I would be interested to know what you think of the handling. I installed the Eibach sway bars on my GTP the night I brought it home from the dealer (14 months ago) which greatly improved the handling. After replacing the OEM GT springs with the Rally's a couple of months ago I didn't notice any difference in the handling. On Austin's GTPE, we installed the Rally springs and Eibach sway bars at the same time so his handling was greatly improved right away.
The Rally springs are much softer and should worsen the handling a bit but since both Austin and I have the Eibach sway bars, we did not notice it. By they way, the Eibach sway bars lessen the bounce if you have that kind of issue because the OEM sway bar mounting bushings are vulcanized to the bars acting like springs and cause the car to bounce up and down a bit more than it should. Adding the Eibach sway bars lessens the bouncy ride and greatly improves the handling.
DevSecNetAIOps, General PITA
Well, count me in on this fun. After I do this I'll go get it aligned at Ford and let them go to town replacing bearings and axles. (that they wouldn't touch or look at because it was lowered) Gotta use that ESP one day.
moncobb
Monty
Vancouver, WA
'21 Mach-e Premium AWD Extended Range
There have been many members here that have lowered their cars with these springs. I've lowered quite a few myself and 2 of them were my personal cars. I never had any issues with BlueCruise and never heard anyone with a lowered car that has. Let's say you don't have a lowered car but you fill the frunk and trunk area with cargo and load the car with 5 passengers. Is BlueCruise not going to work because the car is lower? We can flip that around and there are many here that have lifted their cars with the Rally springs. I've personally installed them in 9 cars and have not heard of anyone complaining about BlueCruise. Maybe I missed this if someone did have issues but I do know quite a few with the lifted car that use BC without issues.
Did you tell the service writer that you lowered the car? Sometimes dealers will use any excuse to get out of servicing a car if they feel there will be an issue. I cannot see why any modules would self destruct either. That is a funny one. Personally I would go to a different dealer and have them look at it and wouldn't mention you lowered it and see what happens.
I did not tell the service writer that I had lowered the car. The shop noticed it independently. By way of update, though, the BlueCruise issue has resolved itself. A tech at my suspension shop told me that he has done mods on Teslas which caused an initial issue with the self driving but those resolved after a few drives. So maybe these systems have some compensation capability. It seems like they would have to be flexible for the reasons you mentioned, like loading. By the way, I totally agree that dealer service writers will invent excuses not to work on a car. That's why I didn't tell them in the first place. I was actually impressed that they noticed the lowering. The module destruction just has to be BS.
