breeves002
- Sam
- Feb 21, 2021
- St. Louis, MO
- 2021 Mach-E GT PE
SSM 49691 - March 25, 2021 - 2021 Mustang Mach-E - Missing Keyless Entry Secure Code Card
Some 2021 Mustang Mach-E vehicles may be missing the keyless entry secure code card. To retrieve the keyless entry code from the body control module (BCM), connect the Ford Diagnostic and repair tool > confirm the VIN > go to toolbox > select BCM – Factory Keyless Entry Code > press Download to retrieve and display the factory keyless entry code > then press Run to get the code.
END SSM
It appears we know why so many are missing cards now...they just forgot them!
It also appears this is not warrantable as they don’t provide a labor code. Most likely your dealer will charge you to retrieve the code, but honestly at the same time they should just do it for free if you bought the car from them. Kind of ridiculous to not know your code.
END SSM
