Suspension Fault Detected and other issues
uncle_0gre
Nick
Colorado
1969 Mach 1 428 CJ
@rsfloodco im also in Fort Collins. I just got this error message today.
My assumption is that it has something to do with how cold it gets overnight.
I took the car for a little drive. Turned it off and back on and the alert went away.
I wonder if the fluid used in the shocks has decreases in volume as it gets cold. When it gets too cold, maybe the volume decreases enough that it triggers the fault warning.
please tell me what Ken Garff says. I’ve only had my Mach e for about a week.
rsfloodco
rsfloodco
Robert
Colorado
2021 Mach E GT PE
Financial Advisor
rsfloodco
rsfloodco
Robert
Colorado
2021 Mach E GT PE
Financial Advisor
They had it for 3 days again and rebooted all the modules they think they needed to. Hasn’t happened again but it only seem to happen 1/3-4 days prior so who knows. On another note, I think they goofed something else up. When I took it out last night, the radio screen was white washed out and unreadable. Took a few shut offs until it seemed to reset itself.
harrysiii
Harry
New Hampshire
'21 MME GTPE DMG; '18 Pacifica Limited
Mine's in the shop today. My errors haven't come back since the first time it happened, but I wanted to have them check it out and at least have this recorded with them anyway. I'll post updates when I hear back.
rsfloodco
rsfloodco
Robert
Colorado
2021 Mach E GT PE
Financial Advisor
Third time wasn’t a charm. The defaults came back after 5 days. Temps near 50 so not a cold issue. Given up on the Fort Collins dealership and going to try the one in Loveland.
harrysiii
Harry
New Hampshire
I brought mine into service on Monday of this week. They actually found a fault in the system from Saturday, which I never saw come up on the screen. Basically what the tech told me is I have a false positive without a secondary type of issue (alert comes back or actual hardware error). The error they found in the system from Saturday was C1132:64. There was no TSB or SSM on this. They also found the previous alert of UO416 in continuous memory; cleared the code and it didn't come back.
I have since received the "Suspension Fault" error one more time.
snickerson123
Sean
Salem, OR
Mach E
Project Manager
I got a suspension fault too a few days ago on my gt pe. Weird. It has not come back on yet.
Ford Mustang Mach-E Suspension Fault Detected and other issues 20211222_180242
rsfloodco
rsfloodco
Robert
Colorado
2021 Mach E GT PE
Financial Advisor
Mines been in the shop since Monday. This is its fifth visit. They can’t get it figured out. Seems to come and go every 3-5days. I’m looking into lemon laws at this point.
chrisGT
Northern California
2021 Ford Mach-e GT
The dealer cannot fix this issue without debugging and guidance from Ford engineers. Clearing codes and resetting the software is not a fix. Have your dealers opened a case and wait for instructions from Ford?
koorb
Brook
2018 Porsche Cayenne 2021 GTPE
Suspension fault on mine today….last three days have had nights below freezing and this is the first I have driven it.
Anybody get any resolution from the dealer service department ?
Thanks
harrysiii
Harry
New Hampshire
Thanks
I had mine checked out by the dealer and they didn't find and issue. The tech told me one of two other things need to happen; it either needs to throw an error code for him that something is actually wrong, or the error has to come right back after he clears it. Mine has come back again one other time, but went away and haven't seen it again.
DevSecOps
Todd
CISO
For those of you having this issue what are the conditions that it presents itself? I.e. First thing in the morning when turning the car on. Releasing the e-brake. Shifting into drive etc.
The only time I've seen this error is when programing the ABS system. That doesn't mean it has anything to do with the ABS system, in fact it doesn't necessarily have anything to do with the Magna system if it's a sister component with the issue. Just probing for a common denominator other than "it's cold".
koorb
Brook
Mine was after sitting in an unheated enclosure for three days in which each night was below freezing. Driving modes were disabled. After driving around for 30 minutes,
the error message no longer appeared when started.
Mach-E GT PE Jim
James
Orland Park
Ford Mach E GT PE
President
Mine has happened about 3 time in the past 3 weeks. Always when I start up the car (it is garage kept but it can get cold). Always goes away. (It is cold but it has happened after being in a 40 degree garage.)
I have a service appointment and will tell them to check with Ford Engineers. I have the Mach-E GT PE as well.
After the warning light goes off, it does not limit the car to 80 MPH's.
DevSecOps
Todd
CISO
Let us know what they find and this error should only be present on GTPEs because that's the only trim with an adaptive suspension system.
FWIW I routinely depart in sub freezing temps and have never seen it outside of programming vehicle modules, which is expected
