Suspicious OBD Scanner Port
ThunderClap
Revanth
Tennessee
MachE GT
Today I tried a OBD scanner with my machine-e and when removing it, I accidentally something else too.
This is the Veepak obd scanner attached to the pass through adapter connected via a wire
Ford Mustang Mach-E Suspicious OBD Scanner Port IMG_7145
Clear view without the veepak scanner
Ford Mustang Mach-E Suspicious OBD Scanner Port IMG_7146
Can anyone confirm if thier Mach-E has this? Or is it even normal? If not, do anyone know what it is?
flapjake314
NYC
Mach-E Select AWD
definitely doesn't come stock with the car haha
have you had the car serviced before by someone? did you buy it used? i'm not even sure it looks the nefarious as much as it is just an OBD2 someone forgot and now you can use...
ThunderClap
ThunderClap
Revanth
Tennessee
MachE GT
No the veepak is mine, i meant the other one in the second image is what i am not sure of.
I bought the car new, just around 3.5k miles
phidauex
Colorado
Renewable Energy Engineer
There have been a few other threads about this - if you don't have a dashcam or similar 12V accessory that the previous owner may have installed and powered with a splitter like this, then the most likely example is a dealership GPS tracker that they left in the car. I'd trace the wire and see what it is connected to. Did you buy (or were offered but declined) some kind of GPS/theft-protection/lo-jack device with the purchase?
ThunderClap
ThunderClap
Revanth
Tennessee
MachE GT
Here is a clear picture of the connection
Ford Mustang Mach-E Suspicious OBD Scanner Port image
And I am not sure of being asked about such thing. Should I call the dealer?
AtomicInternet
SC
Focus RS, Mach E Premium
They put these on used cars and you may or may not have agreed to it in your contract. I brought the device attached to mine back to my sales guy. He admitted I did NOT authorize them to use it and didn't try to re-install it. I don't think there is anything preventing them from installing it, but unless you have wording in the contract that specifically states you have to have it installed you can just toss it.
Tomm
Tom
Davis Ca
2023 Premium
Surgeon
Would leaving it unplugged be just as good as rooting around trying to find it?
Skip Towne
New Hampshire
Mach-E 4x Premium
Maybe one of those insurance "we'll monitor your driving and maybe give you a discount" things?
bmwhitetx
Bruce
2022 F-150 Lightning Lariat ER
The new versions of these trackers are not even plugging into the OBD port. On my wife's new Hyundai, it was wired to the underhood fusebox and double-sided taped to the frame. Has built-in GPS and cellular so doesn't need OBD data. Dealer confirmed it was Lojack type device they "forgot" to remove. Used to prevent lot theft but also to sell you anti-theft service.
Ford Mustang Mach-E Suspicious OBD Scanner Port 1733782605902-t5
Ford Mustang Mach-E Suspicious OBD Scanner Port 1733782640374-xv
Ford Mustang Mach-E Suspicious OBD Scanner Port 1733782717415-6
