Test mule? What is this about?
Plutoman15
Chambersburg, PA
Excursion, Expedition
Ford Mustang Mach-E Test mule? What is this about? A2F3F99D-6BCC-4424-96A0-ADF1131949B2
I was charging beside a Mach-e california 1 model with Michigan plates (in Pennsylvania) and wondered what this modification is all about. An emergency disconnect maybe? With Michigan plates and a number of some sort in the rear window, I figured it was a test mule of some sort. Thoughts?
In my dreams it is Ford testing crazy fast charging ?
JCHLi
Interesting, you say it has MI plates, but did that also say "Manufacturer"?
Polar
SBJ
PNW
2021 Select RWD SR
That’s a lot of gaffers tape.
Plutoman15
Chambersburg, PA
Not sure. The plate looked a little different but I only glanced as I was driving away.
JCHLi
Michigan manufacturers plates would have an M in the middle and MANUFACTURER across the bottom.
It's likely a manufacturer's car, but it is possible someone else was doing some weird testing.
JCHLi
So it looks like, a could tubes or cables going inside just forward of the mirror. One seems to go under the hood and the other towards the charge port. The blue thing appears to be able to rotate and connected to a latch of some sort?
DR.J56
Texas
Any one with a modern truck knows thats where you put the DEF in.
OH2AZ2OH
Dublin, OH
Mach E 4X
But, since it is a Battery Electric vehicle, instead of a Diesel vehicle, that means it needs Battery Electric Exhaust Fluid. I can't wait to see the signs at Pilot and Flying J. BEEF sold here.
Hmm, that's a camera mount with a cable going inside. Looks like it could be a lipstick camera set up for blind spot monitoring. Perhaps Ford is experimenting with using cameras instead of side mirrors, this is something they have mentioned looking into previously.
